DynoFlash [Visit Site]
How does Al control boost with reflashes?
Old May 24, 2005 | 10:09 AM
BOOSTEZ's Avatar
Al (or anyone that knows):
So I'm sure you've tuned and reflashed cars that have Buschur's MAS intake pipe kit. There are 2 hoses that lead to the boost control solenoid. 1) Comes from the wastegate on the turbo. 2) The other comes from the stock MAS intake pipe (which has a nipple on the rubber). Buschur's MAS pipe doesn't have this nipple and therefore this hose would hang. Do you still control boost by keeping the hoses attached to the boost control solenoid?
I just want to know because I have them unattached and using Shiv's passive emulator T.
Thanks,
-M
Old May 24, 2005 | 11:14 AM
DynoFlash's Avatar
The Dyno Flash wuith boost control feature uses the stock factory boost solinoid and boost lines in concunction with revised ecu mapping to control the boost
You nedd to keep 100% stock lines to work with the Dyno Flash boost feature
Old May 24, 2005 | 11:26 AM
BOOSTEZ's Avatar
Ok, so are you saying I need to hook them back up to the solenoid? Fine. But what about the line coming from the boost solenoid and going to the stock MAS intake pipe? Since Buschur doesn't have a nipple on his racing MAS pipe (which I have), does that hose just hang from the boost solenoid controller?
-M
drb
53
Oct 25, 2016 07:50 AM
BOOSTEZ
May 24, 2005 06:24 PM
BOOSTEZ
May 14, 2005 12:39 PM
osunick
May 6, 2005 06:39 AM
viciousv322
Mar 25, 2004 02:50 PM
