DynoFlash [Visit Site]
MBC and flash...
Old Jun 20, 2005 | 06:51 PM
JSYEVO's Avatar
MBC and flash...
well im looking to get a flash and do 21psi, now do i need an MBC or will the boost controlling flash hold it at 21psi? BTW, im on 91oct, will this be safe?
Old Jun 20, 2005 | 08:47 PM
DynoFlash's Avatar
You can do either a MBC - or drill out your boost resitrctor slightly
21 psi is fine on 91 if its just a peak and then fall down towards the red line to 19 or so
Old Jun 20, 2005 | 08:49 PM
JSYEVO's Avatar
i dont think i wanna drill anything so with the MBC do i set it to 21psi after i get the ecu back?
Old Jun 20, 2005 | 09:24 PM
fromWRXtoEVO's Avatar
You should be fine. Al custom tuned my car with 91oct and max boost, I have a Halman MBC and I can hold 1.4bar steady pass 7000rpm.
I am currently peaking about 25-26psi then drops to 20-21psi over 7000rpm but I can maintain way more than 22psi before the 7000rpm
Old Jun 21, 2005 | 04:23 PM
JSYEVO's Avatar
woah how much psi can i do safely?
Old Jun 23, 2005 | 09:27 PM
JSYEVO's Avatar
2 questions...
1. do i set the mbc to whatever psi i told Al to tune it to AFTER i get the ecu reinstalled?
2. how much psi can i push safely with 91 Oct.
Old Jul 18, 2005 | 10:19 PM
JSYEVO's Avatar
bump
Old Jul 22, 2005 | 11:53 PM
DragNRacing's Avatar
2 questions...
Answers...
1) yes although even before should be fine as the car is rich with the stock ECU
2) Al mentioned that you could have it spike to 21 but it should then fall to around 19 at higher RPM's
Hope that helps.
Old Jul 23, 2005 | 08:02 AM
mksevo's Avatar
you will have to have a boost gauge , then you just follow the instruction on the MBC, most say start with it open, then you turn it by 1/2 or 1 turn to adjust up to the boost you want. not to tuff just about 3-4 runs in 3rd and 4th gear to redline will tell you if you need to cont. to adjust. look in the how tos here there is a good write up.
Old Jul 24, 2005 | 07:21 PM
JSYEVO's Avatar
Lightbulb
could al tune the car to hit 23psi on 91 octane with his boost controlling flash?
btw this is with a mail in flash. if not he could do 21 psi correct? so i wouldnt have to get a mbc
Old Jul 25, 2005 | 06:25 AM
DynoFlash's Avatar
2 questions...
1 - yes
2 - 20.5 max psi
Old Jul 28, 2005 | 02:00 PM
JSYEVO's Avatar
and for that 20.5 psi should i get a manual boost controller or can you do that with the flash? which would be BETTER?
Old Aug 27, 2005 | 11:47 AM
go2evo's Avatar
bump for you, i wanna know
Old Aug 27, 2005 | 12:17 PM
DynoFlash's Avatar
1 - NO 20 psi is the max in 4th
You need a MBC to reach 21 psi
Old Sep 20, 2005 | 11:19 PM
go2evo's Avatar
hey Al
and later you said 20.5 psi........which one is "fine" then, like not blow your engine fine. please advice, thanks al
