DynoFlash [Visit Site]
Permanent MR 5k Rev limit
Old Jun 23, 2005 | 12:12 AM
MadMsheen's Avatar
Al, I have PMed you on this issue, but from the recent posts you seem to be pretty busy. So, I thought I would post this question here, as it might also help others with this same question.
I have an 05 MR. After getting Dynoflashed my 5k rev limiter cannot be disabled by removing the plug underneath the clutch. This might not be specific to the MR as another person with the Dynoflash is also having the same problem, but he has a regular 05. https://www.evolutionm.net/forums/sh...4711&highlight I cannot confirm that this is from the Dynoflash, but my friend with a non-dynoflashed MR can disable his, and we have about the same mods.
My questions: are you familiar with this glitch? And are you working on a fix? I don't see myself disabling the rev limit too often, but I would like to have the option.
Old Jun 23, 2005 | 12:29 AM
MadMsheen's Avatar
Correction. Al, seems that the other guy is able to remove his rev limit. Looks like it's just me.
BTW: I am still checking for boost leaks in my car, before I call you on my flash.
If this is not a common occurrance with the Dynoflash, please, disregard this thread. I'll try to check if it is something else. But if it is, any help would be appreciated.
Edit: We removed both plugs under my clutch just to be sure. Still 5k rev limit.
Old Jun 23, 2005 | 12:47 PM
freshevo8's Avatar
pm me and we'll make sure ur pulling the right "plugs" thought i was until i looked hard and found the other plug
