DynoFlash [Visit Site]
Dual stage flash w/ alky?
Old Jul 10, 2005 | 06:32 PM
mooreboost's Avatar
Would it be possible to simply replace the race gas with the meth, and increase the boost as usual?
Old Jul 10, 2005 | 06:34 PM
blueo4's Avatar
meth
Old Jul 11, 2005 | 12:08 AM
titaniumkingpin's Avatar
curious as well
Old Jul 11, 2005 | 05:54 AM
GTVEVO's Avatar
I think you are probably going to find that this could be a very opinionated question. I don't feel that running Meth Injection is better overall than running straight race gas. When you run race fuel you can tune better and be more consistant with quicker reaction due to the EFI fuel system compaired to just one nozzle. On some cars it may not be much different compaired to others so your results will also depend on what you are equipted with.
Just my .02
Old Jul 11, 2005 | 09:02 AM
DynoFlash's Avatar
You dont do a dual stage flash with alcohol injection you run the alcohol all the time and have a single stage
The progressive controller for the alcohol manages your boost
Old Jul 11, 2005 | 11:22 AM
thanks Al for clearing that up.
Old Jul 13, 2005 | 11:48 AM
mooreboost's Avatar
Would you advise against having a tuner run meth with higher boost and only gas with lower boost, on the same map?
Old Jul 13, 2005 | 11:58 AM
TTP Engineering's Avatar
Not if you intend on changing your timing on the meth flash. You will have low boost, no meth and too aggressive timing. You take a lot of fuel away also for meth. Running a single map is not the way to acheive safe reliable results. Utec, AEM and some others have switchable maps for this purpose.
Old Jul 13, 2005 | 01:29 PM
DynoFlash's Avatar
I agree if you run alcohol with a reflash you should run it all the time
