DynoFlash [Visit Site]
whats wrong with my car
Old Jul 19, 2005 | 06:16 PM
Ultimate CC's Avatar
posting under my friends name:
Al im down in seaside for a week. When i come back up to new york ill try to bring it to pruven. This is really aggrevating.
ERIK
Old Jul 20, 2005 | 07:07 AM
Invoice EVO's Avatar
Veteran: Air Force
Originally Posted by DynoFlash
If you can get th car down to Buschur for the week before the shootout - August 13 - I can retune it on the new mustang dyno for you.
The car was without a doubt weak on the alcohol - in fact the weakest one I tuned with alcohol so far. Hopeully it was your o-ring.
What am I looking at for cost of the retune and when will the dyno be ready?
I've asked a friend if he's available to drive my car down the week prior to the shootout. What date specifically should I tell him.
Pete
Old Aug 22, 2005 | 05:01 PM
RLLN247's Avatar
[quote]The only thing i have changed within the last month are my rims. The rims might weigh the same but the tires probably weigh a lot more and it would definitely slow you down some. Have you found out anything on your car yet?
Old Aug 22, 2005 | 07:37 PM
AutobonEvo's Avatar
i just had the same problem iv been trying to get a hold of al he told me hed be there all this week but i just talked to him he told me to call him next week. I have reflash intake BC, exhaust, and i running 13.6 at 102. Stock i ran 13.5 at 104, and when i ran 13.6 there that were stock traping 105 Running 13.4/5, So it wasnt the humidity. IM trying to drive to pruven tomorrow all are you going to be there? if so what time?
Old Aug 23, 2005 | 01:16 AM
TRDHarrier's Avatar
i am in the same situation. My car keeps throwing in a P0300 after the tune...i dunno why...Al, gimme some advice
Old Sep 9, 2005 | 06:52 AM
Veteran: Air Force
Originally Posted by Invoice EVO
I'm in the same boat as you are.
The best I could get with all the supporting mods was a 12.8@106 with a 1.75/60'. Al instructed to change the plugs (gap them to 24) do a compression and boost leak test. Did everything he said and no change. The car does miss in the upper RPM's at full throttle, I also got a code on the EGR. After all was said and done I think the problem was with a bad o-ring on the injector. Most likely the tune was done with the bad o-ring. Al said this could be the problem and needed to be retuned. Even though I would get charged again that wasn't a problem, I just wanted the car fixed and running strong. I ended up missing him at the shootout due to military duties (getting the shaft at work) so no retune.
I plan on haveing the car brought up to Bushcur and have them check everything out and then tune it with AEM EMS. So hopefully all goes well and I get the power the car is supposed to make.
Thanks for trying to help out Al I know you said the car didn't feel as strong as the others after you tuned with the alky. We'll see what happens with the AEM EMS, that is unless you are in Ohio in Sept.
Coming to you from a delployed loaction
Pete
Al,
Dave appears to have found the problem of my lost power. The jet nozzel from the alky was spraying to much and bogging the engine. It was losing hp on the dyno when it sprayed. Just thought I'd let you know.
