DynoFlash [Visit Site]
approx. specs ona a mail in?
Old Aug 25, 2005 | 05:46 PM
honki24's Avatar
Hey, Al I have been trying for-ev-er to get in touch with you via every single form of comunication known to man! Please someone try to answer me this. approx. what AFR is a freshly (mail-in or otherwise) flashed evo running at WOT (just the basics: TB exhaust, intake, mbc). The reason I ask is this: since being flashed I have installed WI (for which I have determined I'd like to run 11.5AFR @ wot) and 264/272 cams (for which I have no idea how to tune). I wanted to know if my current flashed specs are close to that 11.5 AFR. Also, while I've got your attention (that is, if I DO), what is tuned for when tuning for cams? (AFR? timing?)
I basically need to know if it's gonna make a huge difference if I get it reflashed considering I've installed WI and cams.
Old Aug 25, 2005 | 06:33 PM
DynoFlash's Avatar
in your case a custom flash would be needed as I have no support for WI
Old Aug 26, 2005 | 07:22 AM
honki24's Avatar
but you could simply flash it to run @ xx.x AFR correct?
again, what parameters are tuned (how?) for cams?
Old Aug 26, 2005 | 09:56 AM
DynoFlash's Avatar
I do not disclose my settings - its proprietary data
Old Aug 26, 2005 | 01:52 PM
honki24's Avatar
Very understandable. However, I am not asking for your specific settings, I am asking:
1.) Could you flash it to run @ xx.x AFR @ wot?
2.) When tuning for cams (generally) does it affect the AFR?
-Reason I ask is b/c I've calculated that I want it @ 11.5, but if cams change the deal,
I need to know so that I can adjust what AFR I'd like.
(Please understand that I VERY much appreciate your responses, definately much further than I was getting before)
