DynoFlash [Visit Site]
pull timing
Old Sep 17, 2005 | 03:25 PM
go2evo's Avatar
Question pull timing
after dynoflashed, will it has this "protection"? that even if the boost is too high, the ECU itself will get "adjusted" so the engine is protected???
Old Sep 17, 2005 | 04:19 PM
evoviiiny's Avatar
Yes even after the flash the ECU will still detect knock.
Old Sep 17, 2005 | 06:38 PM
DynoFlash's Avatar
Yes - and with proper tuning you will no longer pull any timing unless you get a nad batch of gas
Old Sep 17, 2005 | 09:42 PM
go2evo's Avatar
so al, with your dynoflash that i got, that considers "proper tuning" right?
Old Sep 17, 2005 | 09:58 PM
DynoFlash's Avatar
With normal operating conditions and with the correct tune the ecu should not pull timing unless the fuel quality decreses
However - I think thge original question was IF the ecu can continue to proivide knock protection after the flash and it does
We do not alter the factory knock settings what so ever
Old Sep 17, 2005 | 10:53 PM
go2evo's Avatar
one last question AL so i have no problem setting boost at 21 psi for commuting to work and do 4-5 WOT pull a day under normal condition...providing i use 91 octane...make sense?
