DynoFlash [Visit Site]
TWO Alcohol kits in stock
Old Sep 24, 2005 | 07:16 AM
Deepseadiver's Avatar
I should be getting tuned on Oct 4th or 5th, I am thinking about getting the alky kit before you get here. Do you have any left? is it the same kit from Buschur? I plan on going on a road trip after the tune and had a question about the alky kit. If I drive mostley highway miles and keeping the revs around 3000-4000 (65-75 MPH) would I be using any alky? Dose it only kick on at a ceritin PSI?
Old Sep 24, 2005 | 07:20 AM
BoostWhore's Avatar
yeah u set it to come on at xx psi not sure exactly what psi though
Old Sep 24, 2005 | 07:30 AM
DrBump471's Avatar
The kit is very easy to install and use. You set the boost level for it to turn on (0-20psi) and then you set it where you want maximum pressure from the alky kit to hit (10-26psi). It requires a very small flat screw driver to change.
install was super easy. 4 color coded wires, 2 grounds, tap into a boost line, and a power wire that goes directly into your fuse box underneath the dash. Aside from pulling the front bumper off it was very easy.
I will let you know how it all works out after my tune at 12:30 today. Its full of meth and ready to go!!
any other questions?
Old Sep 24, 2005 | 07:36 AM
C6C6CH3vo's Avatar
Originally Posted by whiteghost
Thanks for the kit Al. I ordered it less than 24 hours ago and here it is. Great service! Its going on as soon as I get off work. Quik question- can toluene be used or is it too caustic on the lines? Has anyone tried using toluene that you know of? I ask because it is available from sherwin williams for a bit less than alky and does not have the h2o content the denatured alky has.
Do not use toluene in that kit. It will dissolve your kit, get all over the place and may catch fire!
Use alcohol (isopropyl, denatured ethyl, or methyl) or distilled h20 only.
Old Sep 24, 2005 | 11:12 PM
DocMortal's Avatar
so 100% methanol is ok............
Old Sep 25, 2005 | 02:00 PM
Pianoman90's Avatar
I have a newb question... how does the installation work out with the tune? I mean, can you install the kit and run without methanol / any alcohol for a week or so until you can get a tune or will this cause trouble?
Old Sep 25, 2005 | 07:40 PM
Al, do you have any kits left?
Old Sep 26, 2005 | 01:43 PM
DynoFlash's Avatar
Just got 5 in today
Old Sep 30, 2005 | 01:55 PM
yesevo's Avatar
Al ..alky Kit U Have Is New Version? What Version Is It??? Can I Install Injection Nozzle On Stock Ic Pipe? Or Do I Need Aftermarket Ic Pipe?
How Much Is The Custom Tune For 2nd Customer? Is There Total Package Price?
I Am Very Interested In...thanks!
Old Sep 30, 2005 | 06:36 PM
DynoFlash's Avatar
This is the newest most up to date SMC kit which has proven 100% trouble free and working great
No package price - I can't even get these in stock - the guy makes them super slow
Custom tune for existing customer is $299 - 350 depending on location
It fits in stock fmic pipe
Old Sep 30, 2005 | 06:47 PM
Blackie9900's Avatar
are u gonna be at pruven tuesday? do u know how much pruven charges to get studs put in? i want a custom tune... and i might go alky the same day... dependign on the head studs.. let me know thnaks
Edit.. i can be at pruven this weekend any time or tuesday anytime (no work or school)
Old Sep 30, 2005 | 07:45 PM
DynoFlash's Avatar
i believe they get $100 to do the studs and $200 to do the alcohol install
We can get it all done on tuesday if you can get there early in the day you will be tuned and on your way home by day's end
Old Sep 30, 2005 | 08:48 PM
alright thanks.. still deciding on wat to do.. areu gonna be there this weekend? i might just get a custom tune now .. and then do more by spring time.. let me know thanks
Old Oct 17, 2005 | 02:25 PM
XxBLACKMAMBAxX's Avatar
Old Oct 17, 2005 | 03:22 PM
DynoFlash's Avatar
They are sold out but more are coming in soon
