DynoFlash [Visit Site]
More smoke after dynoflash??
Old Dec 30, 2005 | 03:45 PM
AUSS1E's Avatar
Anyone else experience more smoke at WOT after getting flashed? I am thouroughly happy with the product, but notice now more smoke when WOT, as though it is running richer than before....Any ideas??
Old Dec 30, 2005 | 04:40 PM
DynoFlash's Avatar
What are your modifications ? I think you have had the flash for a long time if my memory serves me correctly ?
Old Dec 31, 2005 | 07:39 AM
AUSS1E's Avatar
had it for a month or two now. not that long. I have HKS cat-back, Hallman MBC, Koyo Rad, HKS Suction Intake, Defi boost gauge(Set to peak 21 taper to 19)....I had to turn up the hallman slightly after the flash to hit 21psi.
I sent my ecu to you when you were down at Orlando.
I am really please with the performance so far...
Old Dec 31, 2005 | 07:43 AM
smokedmustang's Avatar
When did you get the flash, and after the flash, what new parts did you put on the car?
Old Dec 31, 2005 | 08:21 AM
AUSS1E's Avatar
It was NOV 1st and nothing new just yet
Old Dec 31, 2005 | 10:18 AM
Warrtalon's Avatar
I never have any smoke in any gear under any circumstances - that includes both my previous mail-in flash and current custom road tune.
Old Dec 31, 2005 | 11:12 AM
DynoFlash's Avatar
I would suggest you get the car tested with a wideband o2 sensor and see if its a bit too rich with mail in flashes I have to set them a bit on the rich side anyway
If you get me a log with a wideband i can adjust it slightly
Old Jan 3, 2006 | 03:04 PM
C6C6CH3vo's Avatar
My car smoked a little at WOT pulling out of the dealership with 18 miles on the odometer.
I got a mail-in and it smoked a little less
Then I got a custom tune from a popular vender here and it even smoked more less
There is a procedure for excessive smoking that involves compression testing and oil sampling/monitoring.
Good luck
Old Jan 3, 2006 | 03:08 PM
When I had the "cone" intake, it somehow messed with my MAF. (oil on the filter?) and ruined my MAF. You will have a run-rich mode if its going bad. have it checked at the dealer. mine was reading 35ft below sea-level (I live in Indiana). Got a new one, and problem solved. I went back to the stock box also. The need to plug it in, and check the MUD? sensor. That is the only time I saw black smoke comming out under WOT. Keep us posted.
Old Jan 3, 2006 | 09:28 PM
DynoFlash's Avatar
The LM-1 wideband which I sell at a very low price (can't post) goes a long way to helping to diagnose these kind of conditions
Old Jan 3, 2006 | 10:58 PM
Curt@MrLed's Avatar
Former Vendor
dont believe in a easy breakin huh..
Good luck
Old Jan 7, 2006 | 06:28 AM
AUSS1E's Avatar
would be interested in a PM> Can I use it with a defi gauge?
Old Jan 7, 2006 | 12:19 PM
AUSS1E's Avatar
I am also going to be looking into the possibility of a blown head gasket. Although I highly doubt this as the car hasnt been overheated or overboosed and it is not using oil or coolant.
Old Jan 7, 2006 | 01:13 PM
DynoFlash's Avatar
Do a leak down compression test
Old Jan 7, 2006 | 04:09 PM
AUSS1E's Avatar
I dont have the equipment here at home for that, so cant really get it done without taking it to a shop.
I got 170 solid on all four with a normal compression test.
So I am assuming that this is not the problem.
Next route would be that Wideband. PM Me a price and we will go from there. Thanks
