Wastegate adjustment check
Before i got my tune yesterday i had little problem with boost creep. The car would push 21psi til 5.5 grand and then creep to 24 toward fuel cut. Well i asked around and since i did take every off from the ex mainfold to the 02 to get ported the answer had to be the wastegate. Well the day before tune we tighten it down a little too much which we should of tested and loosened. Well i should of tested it out but it was late and had too get going to SC. Today i loosened up the wastegate a tad. Now its boosting to 21 psi in every gear except 1st! 1st gear every time ends at 19 psi the others gears nail 21 and looks good. I tried the new launch control Al added works great along with a 1st gear roll and it still cuts at 19 psi. Any solutions?
let me also mention in the others gears...my car goes to 10 psi and around 5-6 it then climbs to 21....took the car out again 5 mins ago...1st stoped at 10 psi...i am so confused
Originally Posted by fury656
Theres not enough load in first gear to attain full boost in most instances. Thats totally normal.
