DynoFlash [Visit Site]
***NEWLY RESCHEDULED***: Dynoflash Dyno Tuning Trip - Chicago - February 10
Old Jan 11, 2007 | 07:43 PM
Nood1es's Avatar
sweet cant wait
Old Jan 12, 2007 | 12:13 AM
_EVOlved_'s Avatar
Me too!
Old Jan 12, 2007 | 10:57 AM
DynoFlash's Avatar
I have closed the other thread
Old Jan 12, 2007 | 12:58 PM
projekt_shocker's Avatar
hey al, i have a couple subie guys that are interested in a tune from you... how much would you charge them?
Old Jan 12, 2007 | 10:47 PM
_EVOlved_'s Avatar
Bump for Al!
Old Jan 13, 2007 | 03:58 PM
tarmac IX se's Avatar
how much hp and trq do u gain with the base flash and how much does a flash normally cost??? thanks..
Old Jan 13, 2007 | 04:22 PM
_EVOlved_'s Avatar
A baseflash on a 100% stock IX will get you to, if not a horsepower or two below, 300whp and 300wtq. A fuel pump is highly recommended for that. This is the normal cost.
A custom tune will definitly get you at least 300whp and 300wtq, which is also a normal cost.
Thank you!
Old Jan 15, 2007 | 08:35 AM
Bigoj2's Avatar
What's the Outcome
What would be the outcome with hp and trq after a base reflash on a 04 Evo RS with a Hks Air, Walbro 255, Megan Cat with test pipe?? What else would be added besides the increase in hp and trq?? Thanks for your time
Old Jan 15, 2007 | 08:39 AM
_EVOlved_'s Avatar
You should be at at least 300whp and 300wtq too.
It will raise your MPG, level out A/F ratios allowing your car to run safer and smoother, remove the stock rev limiter, set the 2-step to 5800 instead of 5000, etc.
I can go on for awhile
Old Jan 15, 2007 | 04:03 PM
DynoFlash's Avatar
You can do a search on "case study" and see many of my old dyno sheets with similar mods
Al
Old Jan 15, 2007 | 04:18 PM
_EVOlved_'s Avatar
Yup!
Old Jan 15, 2007 | 06:26 PM
I-Dom-In-8's Avatar
Sorry to say but you will not hit 300Hp and 300Tq with those mods, Esp with a base flash..
Im guessing more in line of 260-270..
Old Jan 15, 2007 | 06:29 PM
I-Dom-In-8's Avatar
Thank you!
Im pretty sure you dont need a fuel pump, You got a nine your fine.. Base flash on a nine stock will be around 280...
Old Jan 15, 2007 | 06:41 PM
_EVOlved_'s Avatar
He should be close with a custom tune
Old Jan 16, 2007 | 08:02 PM
Nood1es's Avatar
actually can i reschudule to 630 i work morning time til 2 and will try to zoom my way there.
