Running higher octane on lower octane flash?
Al, can you run 94 or 95 octane on the 93 octane flash without problems. I found out we do have this at a few select pumps.
Bottom line: would it run faster under its programmed octane or better with a higher octane (not just optimally)?
By the way, thanks for the fast reflash.
The ecu will advance the timing slightly after it sees you are running clear of any detonation - we have several exmples where we picked up significant power on evos just by adding race fuel on the dyno
I don't know what al is going to say, but I run on 91 flash and I mix in race gas w/my 91 and usually have about 93-94 octane. I have no prob,can't really tell if hp improve, and I run alot smoother with mix.
