DynoFlash [Visit Site]
mbc install question
Old Mar 7, 2004 | 02:32 PM
Aby@MIL.SPEC's Avatar
When installing a mbc, should the boost solenoid be completely disconnected & capped off?
I know to disconnect the line from the turbo to the boost solenoid, but should i also disconnect the other line & cap off the boost solenoid?
thanks
Old Mar 7, 2004 | 03:01 PM
DynoFlash's Avatar
I capped off my solinoid and left it plugged it plugged in and zip tied off tio the side
Old Mar 8, 2004 | 08:36 AM
juyanith's Avatar
It may depend on how the MBC was designed. However, **I THINK** almost all of them would eliminate the solenoid since the whole point is that the MBC will control the pressure. Just like Al I have mine capped off and out of the way.
Old Mar 8, 2004 | 09:16 AM
Originally posted by juyanith
[B **I THINK** almost all of them would eliminate the solenoid since the whole point is that the MBC will control the pressure. [/B]
I understand that the mbc is to control boost by eliminating the solenoid, but why disconnect the 2nd line if you dont have too? Its not that i am lazy, but why bother?
What is the 2nd boost line for then? Does this line influence a/f corrections based on pressure or something?
