DynoFlash [Visit Site]
Al, check my timing on mail-in
Old Mar 14, 2004 | 03:25 PM
bishiboy's Avatar
Al, I tuned my mail-in Dynoflash with a Innovate WB O2 and datalogger. I just installed 272s and Walbro 255.
The AFR is 11.0 (+/- .2) all the way from 3K to redline. It seems like it's pulling time around 4500-5500rpms.
The runs was done with pump gas (91), in 3rd gear.
It was about 90F, 20% humidity, 500ft (msl) elevation. Boost set to 20.5 tapering off to 18 at redline.
Cams set with stock cam gears.
This is the raw data. EGT never went above 1550F.
11deg/2535RPM
11deg/2660RPM
9deg/2781RPM
7deg/2934RPM
5deg/3078RPM
5deg/3277RPM
6deg/3469RPM
5deg/3703RPM
4deg/3902RPM
4deg4141RPM
4deg/4375RPM
4deg/4594RPM
3deg/4816RPM
4deg/5039RPM
5deg/5270RPM
5deg/5465RPM
4deg/5691RPM
7deg/5895RPM
7deg/6102RPM
8deg/6293RPM
9deg/6492RPM
9deg/6680RPM
11deg/6879RPM
12deg/7055RPM
12deg/7219RPM
11deg/7391RPM
12deg/7531RPM
12deg/7684RPM
12deg/7820RPM
12deg/7723RPM
Old Mar 14, 2004 | 03:30 PM
bishiboy's Avatar
The Dynoscan read 329hp/294lb/ft.
Old Mar 14, 2004 | 04:26 PM
DynoFlash's Avatar
Bishiboy - I dont have my records with me - was your flash for the CAMS ?
The timing s nce and smooth - should be runnng good - but a lttle low - you could prob pc up a few more whp with a bit more triming - although on 91 octane a custom tune is the best
decent whp numbers for 91 octane though
Old Mar 14, 2004 | 05:33 PM
bishiboy's Avatar
The flash was done before I got the cams.
Do you think if I add some fuel between 4000-6000 it will help with timing?
I'm coming to see you in LA on 10 Apr. This was just to get me by until then.
I'm putting in 680CC injectors this week too, (this is just to prepare for the future turbo kit).
Old Mar 14, 2004 | 05:51 PM
DynoFlash's Avatar
Just as I suspected
You can either send it in for the CAM ign timing map - or just wait till the 10th
Your going UNDER the target on the load refernce on the ign timing maps and running too low a timing
Easy to fix
Old Mar 14, 2004 | 07:40 PM
bishiboy's Avatar
I'll wait, thanks
Old Mar 30, 2004 | 09:39 PM
bpclements's Avatar
Your timing is low man. I remember when we tuned it that day you had 14 degrees of timing from like 6000 to your rev limit at 7800rpms.
