DynoFlash [Visit Site]
Question for Al.
Old Apr 5, 2004 | 09:37 PM
bpclements's Avatar
Question for Al.
Hello Al,
I plan on getting your dynoflash very soon. I just have a couple of concerns. My car seems to run really high EGT's no matter if I am pulling -7 on top or 0 with my afc. At the time I had my mbc set for 17-18psi at redline. I was also only getting 7 to 8 degrees of timing at the most up top. I am running Denso IW24's. I was usually seeing 900 celcius up there. I hit 930 or so once and backed off. These are pulls all in 4th gear running to 7000rpms. It's odd because sometimes I will only see 860 on the top of 4th and I am now running 19psi at red. I don't get it.
I know a friend of mine with the mail in flash and he sees at the most 880 on the top of 4th.
I am wondering if with your advanced timing if I will see safer EGT's?
Thanks for your time,
Barry
Old Apr 5, 2004 | 09:40 PM
DynoFlash's Avatar
Re: Question for Al.
Originally posted by bpclements
Hello Al,
Barry
Your car is too lean even with 0 SAFC correction through 5500 rpms as the HKS RS intake results in super lean
This triggers detonation which in turn retards timing
retarded timing and super lean = high egt
try our HKS RS through the mail flash - if your not happy and seeing lower egts and better timing - then I'll flash you back to stock and give you a full refund - guarantee its the best $199.99 you ever spent on your car
Old Apr 5, 2004 | 10:00 PM
bpclements's Avatar
Wow, thanks for the super fast respond. I will definitely give it a try. I want to get a fuel pump first then I will get the flash. Actually I think I will try and get my ecu off to you this week since I am off of work all week.
Old Apr 5, 2004 | 11:03 PM
DynoFlash's Avatar
I need it to go out tommorrow and reach me by WED of this week
Otherwise it will have to go next week and this thurs through next mon I am in LA
I think you will like the change
Old Apr 6, 2004 | 06:34 PM
bpclements's Avatar
Ok, I can try to get it out to you next week sometime. I'll be in touch. Thanks.
Old Apr 7, 2004 | 11:12 AM
bpclements's Avatar
I noticed that Walbro has two options for the 255lph, the standard one and a high pressure one. Which one would you suggest if I eventually plan to upgrade to a larger turbo such as the gt35r?
Thanks
Old Apr 13, 2004 | 09:07 PM
bpclements's Avatar
Hi Al,
I was wondering how do I purchase the dynoflash from you?
Also, you were definitely right about my high egt's. I added like 6 percent of fuel on top with my afc and the egt's peak out at 860 C on the top of 4th with an O2 voltage of 0.97. The car is running alot smoother. Thanks for the advice.
Thanks,
Barry
Old Apr 13, 2004 | 09:09 PM
EVO8 WHOA's Avatar
Thanks
not to sound mean but isnt it obvious you would want the high pressure one for a Larger turbo like that?
Old Apr 13, 2004 | 09:12 PM
boostnaliljuice's Avatar
hey al i bought the 3037s and wanted to no if the aem is working out for u or what
it's me j with the yellow evo from ny
Old Apr 14, 2004 | 12:19 AM
DynoFlash's Avatar
The AEM is owrking fine now with the patches I got to fix the idel and other problems - However it will never be as good as a stock ecu eith reflash on driveability
You have to deicide if driveability is worth sacrificing the few extra whp you gain when you remove the mas sensor
Call me for details
