DynoFlash [Visit Site]
apexi safc 2 and dynoflash
Old Apr 24, 2004 | 12:45 PM
o00o's Avatar
hey, it wsa said that when you get a dynoflash the safc is set to all "0" cause then the dynoflash would be canceled out cause it fools the ecu and then later if mods are added it can be tuned to adjust, but if you add mods later and set up the safc wont it kill the dynoflash also, so in turn u either get a dynoflash or safc but cant do both together?
Old Apr 24, 2004 | 12:50 PM
zupber4930's Avatar
you can do both together. Just that the S-AFC II will be used to do finite manipulation of the ecu AFTER the dynoflash has been performed. The dynoflash is done to your car for your mods you have done. As you add more...you can use the S-AFC II to adjust settings. Personally I took my S-AFC II out when I had AL do my car. I love it!
Old Apr 24, 2004 | 01:05 PM
o00o's Avatar
heh ya i got mine done too, i just need to wait for him to come back to l.a. then, thnx for information though i just needed clarification on that thnx!
