AARG! 12.08 @ 113.6 but now 11...
Here are his mods, it is really fast for that set-up
Ur Intercooler pipes
TXS Turbo back exhaust
660 injectors
Fuel pump
HKS Rs Intake
264/272 cams
Mr BPV
Utec
Blitz Sbc-id
C-16
I am running 264's on both sides and 100oct. Drove to the track, lowered the tires and ran it, even forgot to take out the baby seats
I have found drinking more helps more better
660 injectors
Fuel pump
HKS Rs Intake
264/272 cams
Mr BPV
Utec
Blitz Sbc-id
C-16
So close! I am sending the ECU in to get a little more aggressive on the timing and lean it out a bit. It was looking really safe on a wideband so there is plenty left in the car. Also switched to a Greddy Type s bov instead of the crushed 1g valve, that alone made the car build boost quicker (see silverserfer write-up on the Type S) and I know it holds better at idle b/c I need to get more fuel added in down low.
just get a cheap safc2 and lean it out at the track!.. keep the safe settings for every day!
you'll easily do an 11 with just a tad more boost and closer to 12-12.1 a/f with race gas in the tank...
Well I went to track last night ran another 12.1 @114.8 with a 1.71 60
My buddy went 12.08 @115.7 with exact same setup as me. Lol he did cut a 1.61 60 which is sick. Still trying but we will get there. Both of these cars are on stock turbo, stock head, no suction pipe, no upper intercooler pipe, stock intake manifold. He has same mods as I do which are listed in sig.
Shane
Shane
Shane
Shane
With the Type S and Al's idle tune the car idles better now (have hks 264's) then it did when stock, no surging, and light throttle bucking is gone! I think am amazed how smooth the car drives in stop-in-go traffic. Only drawback is the Type S sounds like a small bird in under your hood, it chirps when letting off the gas from light throttle.
