DynoFlash [Visit Site]
11 second flashed evo update
Old Sep 21, 2004 | 03:21 PM
evodave's Avatar
From: driving the 10 second beast in ohio or running lightmods.net
Just wanted to update the people who know me and my car. I have yet to make it back to the track but have done a few things. I have messed with the plumbing a bit as i found i had a boost leak on the intake side and who knows how long that was there. I also got rid of my heavier wheels and tires . As many of you know i ran 11.9 first time out with a horrible 1.89 60ft cause of no traction from the power and the 18X9 kinesis rims and crappy (for racing) kumho mx's . I sold those and got 17X9 matte black 5 zigens with 245 40 17 continental contisport 2's .....WOW what difference.
The difference in about 7-9lbs per corner and rotating mass is HUGE. Also, the tires have so much traction its sick. It pulls so hard along with fixing the intake leak that was occuring at full throttle. My plan was/is to get my twin disc carbon exedy clutch in (out with the junky act) and do a sheet metal intake manifold and throttle body upgrade (hard to do with stock ecu though on the throttle body tps voltage). Then get my second ecu tuned for actual race gas timing adjustment since when we ran the 11s previously it was on a 93 octane flash with very conservative a/f's and timing .
Basically my goal is to hit low 11s at around 123-125mph wiht stock head (besides cams and headbolts) and stock bottom end with a ecu flash. The only limiting factor is that i have a .63 a/r exhaust side so my turbo is super powerful and effecient on pump gas and hits 22 psi by 4100rpms if not sooner. We will see i guess. I only need so see 4mph more to get at or around 124 mph and that should definitely get me low 11s as long as my new tire and wheel combo gets me some 1.6 60ft times. Only time will tell...!
Old Sep 21, 2004 | 03:26 PM
VTECH8TR's Avatar
Good luck Dave, 11's with your setup will be easy for you. ...
Old Sep 21, 2004 | 03:51 PM
evodave's Avatar
hahaha
Old Sep 21, 2004 | 06:35 PM
grasshopper's Avatar
dave,i got to come and see you.i need help!
Old Sep 21, 2004 | 06:38 PM
evodave's Avatar
help with what....sup?
Old Sep 21, 2004 | 06:46 PM
i need fine tuning on my flash,i just got an AFC2 so i'm going to mess with that but i don't know any body a round where who know's ****,you look like you do.
Old Sep 21, 2004 | 06:54 PM
evodave's Avatar
yeah i also use a safc2 for fine tuning....do you have a wideband?
Old Sep 21, 2004 | 06:57 PM
no,i should get i'm guessing
Old Sep 21, 2004 | 08:20 PM
Evo11V's Avatar
Veteran: Army
what is your complete mod list?
also what does this mean ".63 a/r exhaust side " for us less unfortunate
Old Sep 22, 2004 | 06:32 AM
evodave's Avatar
yes the .63 a/r exhaust side is the back side of the turbo...it helps spool up a lot with smaller exhaust sides but effects the top end a bit as power levels go up.
Old Sep 22, 2004 | 11:03 PM
mitsuorder's Avatar
Do you mind me asking what problems you're having with the ACT?
Old Sep 22, 2004 | 11:12 PM
evodave's Avatar
oh none really...just going to be getting to around 500whp on race gas and i feel that may be a little over the limit...it still holds pretty good now if you don't slip it too much
Old Sep 22, 2004 | 11:20 PM
mitsuorder's Avatar
OH ok... I see your point. I enjoy mine, took a bit of getting used to compared to the feather lite feel of the stocker. Hey doesn't Turbo Trix use the ACT though?
Old Sep 23, 2004 | 01:41 AM
evo81's Avatar
i think they use the 6 puck version
Old Sep 23, 2004 | 02:41 PM
number 8's Avatar
Thats awesome. I just want to get in the G** Damm 12 second club!!
