what's the max psi on stock evo
i have dynoflashed, how much psi can a stock car w/ dynoflash can get safely? i'm looking to get a boost controller, that's why i want to see what's the max psi i can set for daily drive. any reflash needed AL???? do i need a walbro fuel pump?? do i need a reflash again if that? Stock is running 19 psi, how about after dynoflash?? i don't have a boost gauge yet, i'll get that soon....
how about 21 psi? dynoflashed is set on what psi? thanks alot AL.
Al;
With C16 gas, what is the safest boost level you can run with stock turbo? assume the block is ARP headstudded? |
Originally Posted by Ev0ikon
Al;
Is it possible to run 22psi on stock evo w/Dynoflash and HKS racing suction kit?
even if you didn't have any mods you'll be fine boosting 22 psi if you're on 93 octane or more.
Originally Posted by DynoFlash
Assuming proper tune - 30 psi is no sweat
I got a question this may be stupid but since i kinda need to know i'll ask.... i am getting a Turboback exhaust system in the next few days.. ( catless might i add ).. will i run into any problems without having any kind of flash or what not?? or is it safe to run a full 3" TBE with no flash???
AL...with a manual boost controller, how can i make the boost drop right before the redline? is it fine to hold 21 all the way? and what psi is our car holding after dynoflashed? i will add boost gauge later, but i want to know now, thanks
WOW! I did not know the stock 16G can make so much Boost with C16 racegas. :eek:
Some of them can. I suspect that on some of the stock turbos the wastgates are doing a better job of holding shut than on others. They are adjustable. WQe have not yet played with one as a very small percentage of customers run race gas and want crazy high boost levels With the right tune we have seen many that can hold 30 psi and tapering down to about 25 at red line |
Ideally you would want a MBC (Hallman Pro $90) and a Dyno Flash $199 - that would allow you to maximize the gains from the new exhuast |
| All times are GMT -7. The time now is 03:04 AM. |
