DynoFlash [Visit Site]
what's the max psi on stock evo
Old Nov 3, 2004 | 11:25 PM
go2evo's Avatar
Question what's the max psi on stock evo
i have dynoflashed, how much psi can a stock car w/ dynoflash can get safely? i'm looking to get a boost controller, that's why i want to see what's the max psi i can set for daily drive. any reflash needed AL???? do i need a walbro fuel pump?? do i need a reflash again if that? Stock is running 19 psi, how about after dynoflash?? i don't have a boost gauge yet, i'll get that soon....
Old Nov 3, 2004 | 11:54 PM
DynoFlash's Avatar
You wont need a reflash - 20 - 20.5 psi is a good peak pressure
Old Nov 4, 2004 | 12:13 AM
go2evo's Avatar
how about 21 psi? dynoflashed is set on what psi? thanks alot AL.
Old Nov 4, 2004 | 01:21 AM
Ev0ikon's Avatar
Al;
With C16 gas, what is the safest boost level you can run with stock turbo?
assume the block is ARP headstudded?
Old Nov 4, 2004 | 07:32 AM
DynoFlash's Avatar
Originally Posted by Ev0ikon
Al;
Assuming proper tune - 30 psi is no sweat
Old Nov 4, 2004 | 08:52 AM
MAAGJR's Avatar
Is it possible to run 22psi on stock evo w/Dynoflash and HKS racing suction kit?
Old Nov 4, 2004 | 08:54 AM
bluebanana23's Avatar
even if you didn't have any mods you'll be fine boosting 22 psi if you're on 93 octane or more.
Old Nov 4, 2004 | 09:37 AM
DynoFlash's Avatar
we prefer 21 psi as a max boost peak falling slightly towards the red line
Old Nov 4, 2004 | 09:42 AM
DynoFlash's Avatar
I would qualify that by saying that I would suggest 20.5 - 21 as a max boost on pump gas. Esepcially on the stock exhuast as you start in go higher on boost you begine to build more back pressure which can lead to more knock.
Old Nov 4, 2004 | 09:48 AM
Ev0ikon's Avatar
Talking
WOW! I did not know the stock 16G can make so much Boost with C16 racegas.
Old Nov 4, 2004 | 09:51 AM
steveevo8's Avatar
I got a question this may be stupid but since i kinda need to know i'll ask.... i am getting a Turboback exhaust system in the next few days.. ( catless might i add ).. will i run into any problems without having any kind of flash or what not?? or is it safe to run a full 3" TBE with no flash???
Old Nov 4, 2004 | 06:37 PM
go2evo's Avatar
AL...with a manual boost controller, how can i make the boost drop right before the redline? is it fine to hold 21 all the way? and what psi is our car holding after dynoflashed? i will add boost gauge later, but i want to know now, thanks
Old Nov 4, 2004 | 06:41 PM
johny719's Avatar
Steveevo8... i should be no problem... you might get some inconstantcies and won't be using the exhaust to its full potential... but from atleast for me it was no problem
Old Nov 4, 2004 | 07:03 PM
DynoFlash's Avatar
Not all of them can make 30 psi
Some of them can. I suspect that on some of the stock turbos the wastgates are doing a better job of holding shut than on others. They are adjustable. WQe have not yet played with one as a very small percentage of customers run race gas and want crazy high boost levels
With the right tune we have seen many that can hold 30 psi and tapering down to about 25 at red line
Old Nov 4, 2004 | 07:05 PM
DynoFlash's Avatar
Safe yes - ideal no.
Ideally you would want a MBC (Hallman Pro $90) and a Dyno Flash $199 - that would allow you to maximize the gains from the new exhuast
