DynoFlash [Visit Site]
what's the max psi on stock evo
Old Nov 8, 2004 | 07:26 AM
  #31
DynoFlash's Avatar
Originally Posted by chapter8
Al what is the max boost level one can run with a mail in flash stock block, stock studs and c16. I was hoping for 25psi for the track is this attainable?
Its obtainable - however, in a couple of cases we saw the head bolts strech and the head gasket go over time. Best option would be to replace them with the ARP head studs if you plan on running higher than stock boost levels.
Old Nov 8, 2004 | 08:34 PM
  #32
go2evo's Avatar
what is c16?
Old Nov 8, 2004 | 08:43 PM
  #33
TD05HR's Avatar
Originally Posted by go2evo
what is c16?
Race Gas...
Old Nov 8, 2004 | 11:46 PM
  #34
go2evo's Avatar
thanks
anyone can tell me, what's the boost we are running after dynoflash? i don't have a boost gauge...yet
Old Nov 9, 2004 | 12:51 AM
  #35
go2evo's Avatar
hey al, i already dynoflashed, if i send in for another reflash, is it free?
Old Nov 9, 2004 | 03:37 AM
  #36
EVO8LTW's Avatar
Do electronic boost controllers taper any less than mbc's?
If you get a mail-in flash and later upgrade to a custom flash, is there any discount on the custom flash?
Old Nov 24, 2004 | 08:58 PM
  #37
go2evo's Avatar
bump
Old Nov 24, 2004 | 09:27 PM
  #38
DynoFlash's Avatar
If you have a custom tune - you get free base flashes by fed ex
If you have the fed ex flash now - the you pay $100 for updates
Old Nov 25, 2004 | 01:25 AM
  #39
JDM-Spec.com's Avatar
<< 1.5 bar 21.5 psi
Old Nov 25, 2004 | 05:24 PM
  #40
go2evo's Avatar
talalhz, what are you talking about?
Old Nov 25, 2004 | 05:29 PM
  #41
boostedwrx's Avatar
I run 22 - 23psi on 92 octane, 25 on 110.
Old Nov 25, 2004 | 06:15 PM
  #42
go2evo's Avatar
what's your mod boostedwrx??
talalhz, so you are not dynoflashed?? you only have power fc? why don't you try dynoflash and tell us what's the difference??
Old Nov 25, 2004 | 07:36 PM
  #43
boostedwrx's Avatar
Sorry if its off topic - Cams and gears with supporting mods. 30k miles on current setup, Vishnu tuned.
Old Nov 26, 2004 | 02:54 AM
  #44
EVO8LTW's Avatar
So you aren't running those boost pressures to redline then, right? Doesn't the Xede boost control taper the boost off in the upper RPMs?
Old Nov 26, 2004 | 09:38 AM
  #45
boostedwrx's Avatar
Actually my Blitz SBC-ID only tapers to about 19.5 psi by redline. So I still see a good 22 or 23 psi spike, then it tapers to 19.5 by redline. I believe Al is running the HKS unit, which is probably the best EBC you can buy, maybe he can chime in on how that unit tapers boost.
jackevox
May 14, 2010 08:28 AM
fvaldes
17
Jun 3, 2008 08:42 AM
Joeballz
34
Jul 31, 2006 10:24 AM
03redtype-s
41
Mar 8, 2006 07:28 PM
makaveli_31
44
Sep 27, 2004 07:01 PM
