DynoFlash [Visit Site]
what's the max psi on stock evo
Old Nov 4, 2004 | 07:06 PM
DynoFlash's Avatar
Originally Posted by go2evo
AL...with a manual boost controller, how can i make the boost drop right before the redline? is it fine to hold 21 all the way? and what psi is our car holding after dynoflashed? i will add boost gauge later, but i want to know now, thanks
Normally the stock turbo will naturally fall off from peak boost in a gradual taper to red line
With a nice MBC like the Hallman it will taper about 1 - 1.5 psi to red line
Old Nov 4, 2004 | 07:56 PM
watchout's Avatar
I boost to 27 psi to redline and taper all the way to 21 at redline. Could I have a slight boost leak?
Shane
Old Nov 4, 2004 | 07:59 PM
GreedMOTO's Avatar
I heard the stock turbo is good for about 28psi max and the stock block can handle 32psi max.
Old Nov 4, 2004 | 08:31 PM
DynoFlash's Avatar
The capacity of the stock block is very dependant on the state of tune and type of turbo used
Old Nov 4, 2004 | 09:30 PM
go2evo's Avatar
hey Al, i dynoflashed, other than that basically my car is stock, if i boost up to 21 psi, what would be my whp on estimate???
Old Nov 4, 2004 | 09:34 PM
DynoFlash's Avatar
Shane
I would suggest you try two things
1 - a boost leak test
2 - tighten up the wate gate actuator a bit and see if it holds boost better
I am actually working on a upgraded wastegate actuator piston set up fo rthe evo. Few people realize the amazing boost the stock turbos can make if they are set up the right way.
Old Nov 4, 2004 | 09:35 PM
DynoFlash's Avatar
Average range is 250 - 260 on stock evos with just the Dyno Flash and K & N
Stock is 210 - 240 on our dyno
Old Nov 4, 2004 | 10:28 PM
go2evo's Avatar
cool
Old Nov 6, 2004 | 05:38 AM
GreedMOTO's Avatar
What type of dyno do you run?
Old Nov 6, 2004 | 08:35 AM
DynoFlash's Avatar
Dynojet
Old Nov 6, 2004 | 10:37 PM
go2evo's Avatar
AL, when i get the MBC and set @ 21 psi, do i need a walbro fuel pump and a reflash??
Old Nov 7, 2004 | 05:43 PM
DynoFlash's Avatar
Need - NO
Suggested - yes
Old Nov 7, 2004 | 05:50 PM
dizzigital's Avatar
wow.. SOMEBODY knows their stuff!
Old Nov 7, 2004 | 06:26 PM
2SloEvo's Avatar
Hell yea, Al's the man!
Old Nov 8, 2004 | 06:57 AM
chapter8's Avatar
Al what is the max boost level one can run with a mail in flash stock block, stock studs and c16. I was hoping for 25psi for the track is this attainable?
