Best Turbo for DD E-85 2.0l?
Old Nov 11, 2008 | 11:46 PM
oldevodude's Avatar
If IDC's are 100 percent that means injectors are at 100 percent duty. Reports are A/f going lean due to not enough fuel pressure on rail when you are out of pump.
What size injectors are you running at 100% DC ? Anyway this is what the peeps are saying. RC1150's on FP red at 480 ish HP and stopped upping boost cuz the car was going lean up top.
PS You might need both injectors and a pump depending on how much power you want to develop. In preparation for a Red I just started tuning some new 1260cc Lucas injectors. When Red goes in pump will be limiting factor.
Old Nov 13, 2008 | 12:11 PM
lan_evo_mr9's Avatar
I would go with the red or it would be interesting to see how the full BBK would do.
Old Jan 27, 2010 | 08:29 PM
EvolNinja's Avatar
I want to go with e85 too but afraid it might not start up when temp goes -20 plus wind chills during Jan and Feb. Anyone have any issues with that? I'm looking for safe 400whp to 420whp. Wouldn't 1000cc injectors on single Walbro be good at 400whp?
Old Jan 28, 2010 | 12:29 PM
Jim in Tucson's Avatar
Back to the future, I mean the past, whatever...
Do you get E70 in your area in the winter or E85? If E70, your chances of easily starting are improved. If E85, it may be challenging at those temps. But, I'll let the E85 users in cold climes respond, as I only have to worry down to about 40*
1,000cc injectors with single Walbro is very good for 400whp. Should be good up to about 450whp.
Old Jan 28, 2010 | 02:17 PM
JDMevoBOOST's Avatar
double pumper on a green? You should be good with just bigger injectors and a single pump.
Old Jan 28, 2010 | 07:44 PM
l2r99gst's Avatar
I live in Chicago and have been using E85 all winter. Proper tuning of the cranking IPW tables goes a long way. It isn't going to be perfect at -20, but you should be able to get it started without too much trouble.
Old Jan 29, 2010 | 07:55 AM
EvolNinja's Avatar
Good info. Thanks for the reply. Oh and sorry OP if I high jacked your thread a little
Old Dec 9, 2012 | 04:03 PM
Huy's Evo's Avatar
what does your e85 table for cranking enrichment look like?. i cant seem to dial it in..
Old Dec 17, 2012 | 10:07 AM
10isace's Avatar
That's a good question. I've researched this quite a bit. Have you tried Merlins ECU Tuning Guide?
I'm on FIC 1100 High Z at
360
240
120
80
47.4
14.4
3.704
I'm still having to feather the throttle. I assume that it means that it needs less fuel, but I've been too lazy to mess with it lately.
Old Dec 24, 2012 | 09:04 AM
Levar's Avatar
Veteran: Army
OK. I will also bite the bullet. At 27-30PSI on E85 with a 2.0L engine, I would have to vote for the HTA Green without question, my friend.
Old Dec 27, 2012 | 01:22 PM
soon2bEVOIX's Avatar
I have an 06 MR with FP Red, 23lbs of boost, Aeromotive 340lph pump and FIC 1250cc and i'm at 83% IDC.
Old Dec 27, 2012 | 02:35 PM
mdost03's Avatar
Just an FYI to anyone reading this thread in the future. My cousin has an FP Black on a built 2.0L and running FIC 1450's with a single modded walbro 255 and BAP on e85 and put down 530whp on a Dyno Dynamics. A single 255 on an FP Green is plenty on e85.
Old Dec 28, 2012 | 03:06 PM
RussellDaniel's Avatar
1000CC injectors and a single Walbro is plenty for 400 whp on pump gas. Im running 93 octane and pushing 517 whp on 1100 cc injectors and single walbro.
Old Dec 28, 2012 | 04:05 PM
10isace's Avatar
I'm on a single Walbro at 400hp/tq on E85 at 65% IDC on FIC 1100. You should be fine.
Old Dec 28, 2012 | 04:52 PM
EVOn9ne's Avatar
this thread was started in 07 hah
