Stock ECU E85 settings
Old Jan 9, 2008 | 12:42 PM
BarryC's Avatar
could someone that runs E85 please post up their fuel/timing maps,
also what else needs changing, I read somewhere that the Maf needs rescaling???
I am considiring converting my 1998 Evo 5 rs to E85 as we have it almost everywhere here in Ireland,
Old Jan 10, 2008 | 08:01 AM
merkzu's Avatar
I don't think other peoples maps are going to be all that helpful. Just force the car into open loop, adjust the injector scaling until the car idles/cruises at 14.7. Then let the car used closed loop again and use a datalogger with a wideband to tune the boost areas just like you would with gas while incrementally increasing the boost until you're happy with the tune
Old Jan 10, 2008 | 11:07 AM
BarryC's Avatar
thanks for the reply Merkzu,
the penny finally dropped with this one I thought everyone was rescaling there maps to 9.7 for E85 totally forgot about the closed loop side of things,
anyway thats why ye use 1000cc injectors scaled to 609cc for a given PWM the ecu delivers the injectors will flow more fuel giving the extra fuel needed,
anyway The thing that was putting me off was the fact of having an AFR so lean as 14.7 on a fuel thats stoichiometric ratio is 9.7 in closed loop,
but I guess its not an issue just pull some timing in the lo load areas for idle and cruising,
Old Jan 10, 2008 | 11:10 AM
merkzu's Avatar
14.7 on a gas wideband is stoich for E85 as well, 1 lambda
Old Jan 10, 2008 | 01:02 PM
BarryC's Avatar
yes of course, the sensor is just measuring the ammount of oxygen in the exhaust stream it doesnt know the fuel is E85 or normal gasoline, so when it sees all the oxygen burnt it sends out the relevant voltage for stoich which is 14.7 or 1 lambda, excellent
BTW whats the best way to force openloop??
I tried to up the min temp for closed loop ??
Old Mar 24, 2008 | 10:54 AM
pileofparts's Avatar
Ok, I am burning off the rest of the 91 oct in my tank right now. 1000cc injectors, Walbro 255lph pump, and boost controller. Car idles and runs great on pump gas. Just wanted to double check a couple of my assumptions.
After I fill up with E85 can I just lower the injector size by 30% and check and see how things are running or are there additional steps involved?
I have an evo IX, does it go into open loop when I flash? How do you force closed/open loop?
onefast2gdsm
Dec 26, 2016 02:15 AM
Mr. Castle
E85 / Ethanol
12
Oct 13, 2015 06:46 AM
Cadenas_evo
Driving Techniques
May 21, 2015 01:47 PM
dan l
E85 / Ethanol
15
Dec 5, 2008 02:44 PM
Jim in Tucson
E85 / Ethanol
Jul 21, 2008 09:16 AM
