What kind of boost are people running on E-85?
Old Jul 16, 2008 | 08:52 PM
ccboy37373's Avatar
I have switched to E-85 and I have an Evo 8 with Evo 9 turbo and many bolt ons including HKS 272 cams and ARP headstuds. What kind of boost are you guys running on E-85 with stock turbos? I am at 27spike and about 21-22 holding till redline. I was told I could go a little higher and not hurt anything but I wanted to make sure and I also dont want to waste my time blowing hot air.
Old Jul 16, 2008 | 10:26 PM
Jim in Tucson's Avatar
...28 psi tapering to 22...
Old Jul 17, 2008 | 07:49 AM
merkzu's Avatar
30psi to 23-24, might even be able to peak higher
Old Jul 17, 2008 | 09:58 AM
churchja's Avatar
29.5 psi to 23-24
Old Jul 17, 2008 | 11:02 AM
skiracer's Avatar
28psi tapering to 22psi....
On the dyno i cranked it up to 30psi, but it didn't affect power levels much. So i guess 30psi is just blowing a bunch of hot hair
Old Jul 17, 2008 | 12:36 PM
bzzbee2's Avatar
I only went up to 28 on the dyno. however for daily driving i keep it at 24. Since this is still pretty new to the evos, i plan on driving at no higher than 24. When im racing (rallyx) it gets turned down to 18.
Old Jul 17, 2008 | 01:20 PM
skiracer's Avatar
I've ran on road course tracks at 25psi on E85 and car runs fine during the 20 minute sessions
Old Jul 17, 2008 | 01:24 PM
Wicked E's Avatar
32 Map
-e
Old Jul 17, 2008 | 01:26 PM
Do any of you tracking your EVO have an EGT gage? What are you seeing compared to EGT's on the same track/event on 91/93?
E85 is supposed to burn/run cooler, but if the boost is turned up on E85 that may off-set any "improvement".
Old Jul 17, 2008 | 01:29 PM
skiracer's Avatar
I have an EGT gauge and mine is about 25-50 Celcius cooler peak temps compared to 91 octane at 25psi. At 28PSI, EGT's are about the same as 91.
Old Jul 17, 2008 | 01:34 PM
evolution2186's Avatar
I have installed 850cc injectors along with pump, and will be tuning for E on monday, however I will keep boost around 25 psi for daily driving. 27.5 max for the track.
Old Jul 17, 2008 | 02:03 PM
bzzbee2's Avatar
Does anyone have one of those E85 Content gauges that are being sold somewhere in the forums. I believe its based off the GM sensors and detects the percentage of E85 that you get from the pump. I would think this would help so that you could fine tune for what ever % e85 you get...
Old Jul 17, 2008 | 02:04 PM
AWD Motorsports's Avatar
30+psi spike.. stock turbo, stock ecu..
Old Jul 17, 2008 | 02:07 PM
whoang40's Avatar
23.6 tapering to 20 by redline.
Old Jul 17, 2008 | 07:35 PM
ccboy37373's Avatar
Mike...I was hoping you would post! I think ill go with his setup at 30psi b/c this guy knows his ****.
For those who disagree look up a Evo with a guy named CWill!
