Any help? Lean A/F @ high RPM
Old Sep 9, 2008 | 12:10 PM
  #31
kcevo's Avatar
Originally Posted by JohnBradley
Exactly and the IDC's were in the low 80s with 1200s ( I have done that one as well...even double checked a log to make sure I wasnt lying).
However what I was trying to say is that as the fuel demands go up right about 5500 (where you notice the fuel pressure drop the most, or conversely where it will richen up with a bigger pump) is right where you are having the issue. To me its like the guy that throws a 255 in without the install kit and gets the same exact symptoms. I have a full blown unit but I havent looked at it in awhile. Do they need something similar to keep the pump tight against the top nipple or is it machined to fit tight to begin with? In the aforementioned case thats where it bypasses and since you have 2 pumps AND 1200s I really doubt you would have noticed it on gasoline since you'd never run out of fuel for the amount of boost you can run on 91.
It sounds like either an FPR issue or a pump issue to me.
The reason for the issue at around 5500 to 6000 is becuase I can't add any more duty cycle to the injector with the map as they are maxed out and that is the reason it is steadily going leaner in correlation to RPM out to redline. The 2nd pump is coming on at around 5 pounds with the provided Hobbs switch that was provided with the dual pump hanger from Full-Blown.
The Full-Blown kit didn't come with any fittings or anything and the customer is using the stock lines from the pump to the rail and from the FPR to the tank. We sourced all barb fittings and 5/16" fuel line for the feed and siphon from the passenger side tank. Also the pumpgs don't sit up in the dual hanger like stock where it is up against the housing where the pump nipple sits in the female housing of the stock hanger. It requires the need for more fittings and fuel line to place the pumps at the bottom of the hanger so they sit just as low as the factory pump would have it, measured and checked many times.....did this same thing for the return T fitting for the siphon and return from the FPR to make sure they were as low in the tank as factory.
Reason I don't think it was bypassing the pumps in the beginning of tuning 91 is because the IPW's I was commanding in the 91 tune that tuned out great with 11.3 afr's; this was the same tune put back in when we switched it back from E85 to 91 octane and now the same IPW's gave me 16's for afr's. It vary well could be something in the pump assembly that went wrong, but it also could be the FPR which is what I'm gonna test next; then go back to digging at the dual pump setup again for anything out of the ordinary if the FPR doesn't fix it.
Old Sep 10, 2008 | 07:17 AM
  #32
2muchboost's Avatar
Let us know if you find a fix please.. My next step is to just add more fuel through the fpr. I know its just a band aid fix but i dont know what else to do..
thanks!
Old Sep 10, 2008 | 10:45 AM
  #33
kcevo's Avatar
thanks!
Will do....if it is the FPR the customer is going to switch to an Aeromotive universal unit and AMS fuel rail as well....I'm sure the stock fpr and rail would do just fine he would just like to upgrade.
Old Sep 12, 2008 | 08:11 AM
  #34
Jeeperjunior's Avatar
Ok, so the FPR did not fix the problem. We're going to try to mess with the pumps tonight..
Razorlab so far all you have done is been a smarta$$. If your looking for drama go to the theatre, because your not any help here.
Old Sep 12, 2008 | 08:53 AM
  #35
denver's Avatar
Just throwing it out there..... It sounds like this is a fuel delivery issue for sure, you said you checked the pumps, changed the regulator rail, etc.... since the tune worked before and now doesn't is seems the only likely things to replace are thing which can fail aka regulator/pumps.... or clogging issues aka the rail, lines or injectors....... if it were me, I would try back flushing the fuel injectors. It is very likely that since you are not running a filter small particles can get inside your injectors and hinder flow. What I have done in the past is get a spray can of B12, or any pressurized fuel system cleaner. Find a piece of fuel hose that fits over the output side of the fuel injector then somehow build up the diameter of the red spray tube that comes with the cleaner to fit tight in the fuel line. (I used a lathe made piece to fit tight on the injector and tight on the tube) then apply 12v to the injector low current, I used a 12v 1amp battery charger....... spray the cleaner in reverse through the injector...... if you do it over a white paper towel you will be amazed at all the junk that will come out! Repeat till your towel is clean. Note Do Not hold the injector on for more than about 30-45 seconds at a time.... It usually helps to have an assistant b/c holding it all together gets to be a bit tricky and I definitely recommend wearing a face shield.... if a line leaks and sprays you in the face IT BURNS A LOT!
Old Sep 12, 2008 | 11:05 AM
  #36
We're using an inline filter and the injectors were just put in b4 tuning began.......
Old Sep 12, 2008 | 11:12 AM
  #37
denver's Avatar
Oh ok, I missed the inline filter.........
I have seen injectors get clogged on just one or two runs. Its possible that you had a deposit somewhere in a line and when you put the e85 it made the deposit go into solution and clog up....... Worth checking IMO
keep us posted of what the cause is.
Old Sep 12, 2008 | 04:57 PM
  #38
RazorLab's Avatar
Is this a joke? Are you for real? Really? Let me quote all my questions and suggestions I had in this thread.
Originally Posted by razorlab
What are the IDC's telling you?
Again, what are the IDC's telling you?
You obviously have a fuel supply issue somewhere when the system is being asked for a higher demand.
Are you sure your secondary pump is working/on?
9ms at redline? 16:1 afr? At 7k that's 52% IDC
Are you sure your wideband is reading correctly?
Out of curiosity, what does the narrowband 02 sensor say?
I'm just confused now. You keep throwing around all these different IPW's I don't know what is what anymore. You said 9ms before at redline, now you are saying 22ms at redline.... 22ms at 7k is almost 130% IDC.
I take it you have checked your inline filter?
I had a problem where my AFR's suddenly leaned out from 11.8 to 14.4 at WOT. Ended up being my fuel filter was clogged.
Ok,
So have you gone back to 91 oct? And everything is ok again with 91? No fueling issues?
If so...
What are you scaling the injectors to when you switch to E85? They should be scaled approx 70% down. For example, 1000cc injectors scaled at 860 for gas should be scaled down to approx 580 for E85
All the same questions and suggestions everyone else is inputting in this thread. So I guess everyone sucks.
I guess I will think twice before trying to help people now...
Old Sep 12, 2008 | 05:08 PM
  #39
JohnBradley's Avatar
Wow, just wow.
KCevo-
Anyway so have you checked the voltage at the pump to make sure its not dropping way off? I am thinking that since this was fine beforehand, then switched, and switched back yet again and then still lean that something either in the feed or voltage is whack.
Those use a relay to maintain voltage right? Maybe a burnt out relay? Have you pulled the pumps to make sure that both are purring? I think when you get it everyone will end up doing the "oh yeah of course" thing.
Old Sep 12, 2008 | 06:35 PM
  #40
We're pulling the pumps as we speak. We're going to check the voltage. Thanks. I'll fill u in asap.
Old Sep 12, 2008 | 06:41 PM
  #41
God I love when people come in asking for help and get all pissed when they don't hear what they want.
If you wrote your posts in a easy to read way instead of different IPW's flying all over the place (example being you said IPW was 9ms for both 91 and E85 then later you said it was 22ms for E85), I would understand them easier and not re-ask questions.
Sorry for trying to help. Good luck.
I do appreciate help, but I don't appreciate comments like this one and having to repeat what has already been stated multiple times. It clutters up the thread.
But back on topic, i think we may do away with the hobbs switch and drill out the tee fitting.
Old Sep 12, 2008 | 07:00 PM
  #42
denver's Avatar
Is it possible to check the function of the hobs switch? Im going to say it again.......if it worked before it should work again, there must be a clog or a failure......
Old Sep 12, 2008 | 07:03 PM
  #43
RazorLab's Avatar
Good luck with the problem.
Old Sep 13, 2008 | 10:18 AM
  #44
awdboosted's Avatar
Are you still running stock lines?? That could be a restriction?? I would look into do at least -6 an line. Just a thought.
Old Sep 13, 2008 | 10:03 PM
  #45
Aby@MIL.SPEC's Avatar
LOL, did I make the post?
This isn't my first rodeo
FYI, you may want to do a search for my username as it may come in handy for you to get your AEM UEGO to read properly in your AEM EMS.
Your right....sorry about that.
I thought i clicked paged 1 & I scrolled up.....I saw your post on top of page 2, thinking it was page 1....yeah, maybe i ought to try this new thing called READING
sorry bro btw, i havent had / made the time to try your suggestion....thanks
