Another cornfed on the list
Old Oct 7, 2008 | 07:18 AM
lan_evo_mr9's Avatar
Just got dyno tuned for 93 and E85. Unfortunately I had mixed results due to phantom knock being registered from a bad PS pump shaft and my forge boost controller wouldn't let me go any higher than 25psi. With the phantom knock the ecu was pulling ALL timing. With that said I still laid down 390hp/tq. So needless to say there is alot left in her. She's going to the dealer to get the pump replaced and then going back to the dyno for the real numbers. I guess I'm going to adjust the wastegate rod a little for the boost concern. I'm thinking she should lay down close to 420 when running properly. All in all a great day- still picked up 20hp with NO timing advance and 25psi.
Old Oct 14, 2008 | 08:05 PM
eitan's Avatar
You should see quite a boost just from bumping the timing up. My car is a dog if it's not running enough timing.
