Base Low Coolant Timing Map
Old Oct 28, 2008 | 12:11 PM
oldevodude's Avatar
Originally Posted by lan_evo_mr9
Tell me about it- so annoying. If front o2 is all over the place what should I do with the latency at 14v- raise or lower? From -8 to 20 I have 49,27,20. Is that close to what you have? Sorry for the obcious questions but the wideband is in the mail. I have .624 for 1000 fic's at 14v.
.624 seems way too low for FIC 1000's Like Bryan said your Injector scaling is more than likely way off which complicates your cold start on e85. (what are your logged trims any way? )
Old Oct 28, 2008 | 03:03 PM
oldevodude's Avatar
Sorry double post
Old Nov 1, 2008 | 12:34 AM
fixem2's Avatar
Anyone have this table def for 96530006?
Old Nov 5, 2008 | 02:06 PM
Jeff_Jeske's Avatar
I'm on stock injectors with fuel trims dialed in. I'm still having cold start issues when temps drop to about freezing it takes a good number of cranks to pop off.
60* and up the thing pops off like it did right off the showroom floor. What variables have you cold weather folks adjusted to enable quick starting when cold?
I am catless and do not have emissions testing to worry about.
Old Nov 5, 2008 | 02:13 PM
RazorLab's Avatar
On normal gas?
You can try adding cranking IPW at those colder coolant temps
https://www.evolutionm.net/forums/sh...d.php?t=347668
Old Nov 6, 2008 | 03:43 PM
Jeff_Jeske's Avatar
I was running E85 until the temps drop. Just curious if we have found a cold start fix yet.
Old Nov 6, 2008 | 03:51 PM
RazorLab's Avatar
For E85 the cranking IPW tweaks help/fix
doom26464
Cobb AccessPORT
Sep 6, 2013 11:45 AM
pbassist12
22
Jul 2, 2012 06:57 PM
dldjros69
Cobb AccessPORT
May 31, 2012 03:06 PM
ninekrevs
Mar 8, 2011 04:27 PM
CaptianSellout
Dec 11, 2010 01:37 PM
