What size/ brand of injectors do you use for E85?
Old May 13, 2009 | 07:22 PM
evane's Avatar
Like it says...What size/ brand of injectors do you use for E85?
Old May 13, 2009 | 09:50 PM
RoadSpike's Avatar
Precision 1200cc's
Tried the FIC's but i had horrible luck i know other people love them but after two sets i was kinda fed up.
Old May 13, 2009 | 10:05 PM
skiracer's Avatar
RC Engineering 1000cc works fine for my stock ix turbo...
Old May 13, 2009 | 11:28 PM
GST Motorsports's Avatar
we've tuned a ton on RC 1000 and 1200 on E85. Work great.
A couple on FIC BlueMax 1450cc and 1250cc.
Old May 14, 2009 | 12:21 AM
oldevodude's Avatar
Custom modified Lucas based 1200cc here
Quote about disc based injectors from internet.
Top feed disc injectors use a small disc with six holes around its circumference. The disc rests on a short chimney that surrounds a metering hole. As the disc is raised off the chimney by magnetic force, fuel flows through the holes in the disc, over the walls of the chimney, and out the metering hole to form a full, finely atomized cone.
Performance advantages over pintle injectors (i.e. Ford / Bosch & Accel types) as listed by Delphi:
• The flat mating surface ensures that no excess fuel is present to evaporate and therefore, no deposits or clogging can occur.
• Compatible with alternative fuels (i.e. E85, Methanol)
• Longer service life
• High-speed disc action allows wider dynamic flow range for improved idling
• Quieter operation
• Revolutionary disc design resists build up deposits which can affect fuel flow.
• No Fuel leakage for quicker starts
no mal intent against RC here but.....
Lucas on left RC on right
PS mine have stainless steel bodies but are Lucas 120 lb.
Old May 14, 2009 | 06:32 AM
rawburt's Avatar
Precision 1000cc
Old May 14, 2009 | 07:33 AM
dsmfan95's Avatar
Had RC1000's with the EvoGreen.
Have PTE1200's with the EvoRed.
Old May 14, 2009 | 07:49 AM
logic's Avatar
I currently have a set of overworked PTE 880s on the Evo, but I have my eye on a set of ID 1000s for both it and my wife's WRX.
Old May 14, 2009 | 09:01 AM
skiracer's Avatar
I ran Denso 660cc on E85 for 6 months. Now that's being overworked..
Old May 14, 2009 | 09:10 AM
dmoevo's Avatar
precision 1000cc
Old May 14, 2009 | 01:47 PM
sslevo's Avatar
PTE 1000's here as well, car idles and starts like stock on 93 and corn. No problems here.
Old May 14, 2009 | 02:39 PM
LV///R's Avatar
FIC 950cc's.
Old May 14, 2009 | 02:47 PM
evane's Avatar
so far it looks like PTE is the number one choice....bump for more!
Old May 14, 2009 | 02:54 PM
ROGERV's Avatar
PTE 1000cc on Green
FIC 1450cc on Red
Old May 14, 2009 | 02:55 PM
tkklemann's Avatar
FIC1050's here, and one of the few without problems.
