To those running E-85..
Old Aug 11, 2009 | 09:29 AM
thermaldynamics's Avatar
I use a cheap 100ml graduated cylinder that I bought off amazon.
Fill it 50ml with ethanol then fill with water up to the 100ml mark. Use a rubber stopper or something to plug the end and shake. Let it settle and the fluids will separate. The ethanol will mix with the water and the gasoline will settle on top. Read the level at where the two mixtures are separated. The math would go something like this: ((Level where fluids are separated / Orig Amt Water (50ml))-1
So if you have a 100ml grad cylinder, use 50ml ethanol, 50ml water, shake, the new level where mixture separates = say 90ml (90/50)-1 = 0.8 or 80% Ethanol
Use the flash on knock light and monitor your afr's. I think there is a website somewhere that lists the time of year where different regions in the US make the switch to E70 for cold weather and back to E85 for warmer weather. Make your tests during these times or just switch back to 93.
Good luck
Old Aug 11, 2009 | 09:37 AM
phenem's Avatar
Originally Posted by project_skyline
I would recommend the map switch kit by jack of all trades, it comes with everything you need and some great instructions. I plan on getting it here soon when i get some extra money.
Do you have a link to this thread or any info on it?
Old Aug 11, 2009 | 09:40 AM
travman's Avatar
http://www.dsm-ezine.com/evoVIII_adc_switch.html
Old Aug 11, 2009 | 09:43 AM
phenem's Avatar
That is just the regular map switch kit, I was assuming he was referring to a new kit that has an e85 sensor in the gas tank and calibrates your octane level based on the mix of e85 vs. 93 octane gas.
Old Aug 11, 2009 | 06:33 PM
travman's Avatar
That was what I thought you were asking for.....my bad.
There is a patch mrfred will be releasing...but you will have to have the zietronix ethanol analyzer + ethanol sensor.
Old Aug 12, 2009 | 11:16 AM
rawburt's Avatar
How do you set this up?
Old Aug 12, 2009 | 11:46 AM
CoMoEvo's Avatar
^+1
Old Aug 12, 2009 | 04:17 PM
Tephra mod v5.1
If you see the light coming on when you did not make any ecu or physical changes to the car its a good indicator to check something out (like the fuel) ie something changed to make the car start knocking and trigger the light. Note: You need to start with a good tune.
Read up on the Tephra mods to learn about this feature.
Old Aug 13, 2009 | 03:51 AM
project_skyline's Avatar
Oh I was just referring to the duel maps switching kit. Mrfred is working on something but nothing else along those lines are available.
Old Aug 21, 2009 | 08:31 AM
resart's Avatar
This is very educating.
I am learning more and more.
Thanks guys.
jracer
Jun 15, 2016 05:08 PM
Chris@nolimitmotors
EvoX 'For Sale' Electronics / Lighting / Audio
187
Dec 11, 2015 08:34 AM
TTP Engineering
21
Dec 1, 2009 12:03 PM
EVOlutionary
E85 / Ethanol
23
Apr 18, 2009 12:13 AM
Kc2Buk
61
May 5, 2006 11:39 AM
