No gains from e85
Old Mar 7, 2012 | 07:31 AM
David Buschur's Avatar
Originally Posted by Evoryder
Next mod, new tuner.
haha, you are right!
Old Mar 7, 2012 | 09:25 AM
_des_'s Avatar
Old Mar 7, 2012 | 10:09 AM
deylag's Avatar
Yea I saw gains when I switched to E-85. I got my Evo tuned on 91 first then on E-85. I saw a 70 hp gain plus a 50 tq gain.
Old Mar 7, 2012 | 10:21 AM
tiggeryellow1's Avatar
Veteran: Army
Sky is the limit on E85... E98... Q16... or wherever you wanna go with higher octane fuel. But don't be surprised if you hit that threshold early on your basic bolt on mods. I'm jus sayin you're gonna hit a wall where you're going to NEED to free up some more air and increase the flow of your fuel to make even MORE POWA!
Old Mar 7, 2012 | 10:37 AM
Spec-Ops1's Avatar
I am in Jacksonville, FL and have tuned quite a few people on E85 lately, not to mention I have been running E85 for the past 2 years...
Old Mar 7, 2012 | 11:19 AM
02nfr_s2k's Avatar
even people who don't tune cars know that e-85 will increase powaaaaaa!!!
next tuner on your list....
Old Mar 7, 2012 | 11:32 AM
hotstix's Avatar
Run.As fast and as far from that tuner as possible.
Old Mar 7, 2012 | 11:37 AM
Anarchy99's Avatar
Originally Posted by VR4-EVO
Hello everyone!
I called my tuner because I was ready to get a tune on e85. I told
Him my list of mods and he called back the next day and said that there would be no real gains from e85 on my car. I just wanted to get more opinions to make sure.
Mod list: MBC, TBE, upper and lower I/c piping, 10.5 hotside, evo IX bov, Megan o2 dump, walbro 255, and 1050cc injectors tuned at 24psi. He said there would be no real gains since I'm pushing the effeciency of the stock turbo and should steer instead on getting a new intercooler. Any thoughts?
Went from 338whp to 404whp on stock turbo on E85.
You need to never go back to that joker as he has no clue what he is talking about and obviously has never used that fuel
Old Mar 7, 2012 | 11:39 AM
ssg_petty_210's Avatar
Get a different tuner. There are def gains to be had from tuning on E85.
Old Mar 7, 2012 | 12:07 PM
sc_s13's Avatar
I'm in Huntsville Alabama. So Mellon isn't too far away. Is my drivetrain still safe at what the new power levels may be? Assuming I'd be in the mid to high 300's? The car isn't tracked, and Hasn't been launched. I just want more power. Haha. But not at the expense of a few pulls tearing apart the drivetrain.
You're drivetrain will be fine providing you know how to shift it. You need only to upgrade to a twin plate once you cross the low 400 numbers and plan on running it harder. I'm running 450whp on a stock clutch and its not the best setup, but it works for DD'ing and occasional pulls. Definitely looking to replace it in the near future however.
The trans in naturally a bit weak in higher gears so it's wise to eventually get it worked on at Shep, Buschur Engineering, or TRE. All these companies have excellent track records and competitive pricing on rebuilds or exchanges.
Old Mar 7, 2012 | 02:39 PM
ajnasrah20083's Avatar
a stock Evo motor will hold 400whp no problem.
Old Mar 8, 2012 | 04:45 PM
boostless's Avatar
Originally Posted by evoryder
next mod, new tuner.
+1
Old Mar 9, 2012 | 03:10 PM
Mellon Racing's Avatar
it's pretty common for 350awhp pump gas guys to get 380-400awhp on e85 even in the summer heat. Once you're car is making nearly 400awhp on pump gas getting big gains on e85 diminishes somewhat because the stock turbo is nearly maxed out already.
Old Apr 8, 2012 | 12:51 AM
thefriskyevo's Avatar
Originally Posted by escodotcarter
your tuner is a dumba$$
Pretty much
Old Apr 9, 2012 | 04:39 PM
spoolinevo9's Avatar
I'm from scottsboro my evo was tuned by mellon it will be the best thing you will ever do.
