review my map...
Old Feb 16, 2015 | 12:39 PM
Jose06EVO9's Avatar
review my map...
what's up guys...
I need help with a map I pulled from my car, can someone take a look and give me your opinion. Car does not feel right under boost and I'm a little scared that the afr's are in the 12.4 top end. I get 4-5 counts of knock, so I have my suspicions that this map needs work. I just need a second opinion as I am still learning how to tune.
Mods on car:
full exhaust
cosworth cams
injectors, previous own said 1100cc (I'll verify when I get home)
e85
manual boost controller (will be changing it out to grimspeed)
stock head
stock engine
The first concern is that I had to use 88950015 xml file and edited the rom id to read 95880015 in order for ecuflash to read the rom. I think the pervious tuner changed the rom id to try and lock the map. would the rom download correct if I used a base 88950015 xml file with just the edited id? or would the downloaded rom inherit the base settings from the original xml?
The second thing that is concerning is the fuel scaling does not seem right, I would of thought that with the 1100cc injectors the map would have a higher scaling than what the map reads even on e85?? this is why I asked the first question.
I appreciate your help guys!
File Type: xml
File Type: hex
Old Feb 16, 2015 | 02:25 PM
Jose06EVO9's Avatar
I need an Admin. to move this to the General Engine Management / Tuning Forum, please!
Thanks!
Old Feb 16, 2015 | 07:37 PM
Jose06EVO9's Avatar
anybody???
Old Feb 26, 2015 | 08:02 PM
gSx's Avatar
gSx
cant tell ya too much without logs.. well its likely surpassing MBT with 19 degrees out the top which is pretty aggressive for a stock motor. are you running a stock turbo?
novaspyder87
Mar 18, 2016 08:00 AM
neonglh
123
Sep 16, 2011 12:20 PM
Blue Evo 8
18
Jan 10, 2009 02:33 PM
jackygor
Nov 29, 2007 09:57 PM
