Analogue output FF
It depends on which flex fuel ECU patch you are using and which ECU you have. For example, if you are planning to use AST's FreeFuel ECU patch it uses an analog DC (0-5V) input connected to the ECU pin that is used for map switching:
- Evo 8 4-plug ECU: pin 42
- Evo 8 3-plug ECU: pin 64
For an accurate answer, let us know which ECU you are running, which ROM ID, and which Flex Fuel patch you plan to run.
Biggiesacks
Mar 11, 2016 01:03 PM
Biggiesacks
Mar 9, 2016 02:08 PM
