EcuFlash stationary rev limit work on 03's
Old May 16, 2006 | 10:05 PM
mercedevo's Avatar
I'm woundering if the Stationary Rev Limit would work on the 03 Ecu since it didn't have this feature?
Old May 16, 2006 | 10:15 PM
mercedevo's Avatar
Also, How does the Ecu determine which octane fuel map to use?
Old May 16, 2006 | 10:21 PM
vegasboy301's Avatar
yes.... it works... ive seen it done... that works and the rev limit raiser works, and the everything
Old May 16, 2006 | 11:25 PM
1slowevo's Avatar
yes it is actually quite easy to do as a matter of fact.
Old May 17, 2006 | 12:03 AM
Noogles's Avatar
the ECU will decide on what map to run off of depending on the voltage reported back from the nock sensor, the highrt the voltage the more timming it will pull. Eventually it will settle into the Low octane map to protect itse;f if it keeps nocking.
Old May 17, 2006 | 03:28 AM
vboy425's Avatar
okay so hwo do you set the stationary rev on 03 and 04??
Old May 17, 2006 | 05:00 AM
MalibuJack's Avatar
Yep, it works.. Just set the RPM in the Stationary Rev Limit data item...
Old May 17, 2006 | 08:53 PM
mercedevo's Avatar
can't wait to try it. thanks
blitzkreig
Jun 20, 2016 10:35 AM
GeoMitsu
Nov 14, 2013 04:22 AM
ant_turbo
Oct 29, 2009 08:37 PM
Evo_Pma
Jul 6, 2007 09:32 AM
