EcuFlash stationary rev limit work on 03's
I'm woundering if the Stationary Rev Limit would work on the 03 Ecu since it didn't have this feature? :confused:
Also, How does the Ecu determine which octane fuel map to use?
yes.... it works... ive seen it done... that works and the rev limit raiser works, and the everything
yes it is actually quite easy to do as a matter of fact.
the ECU will decide on what map to run off of depending on the voltage reported back from the nock sensor, the highrt the voltage the more timming it will pull. Eventually it will settle into the Low octane map to protect itse;f if it keeps nocking.
okay so hwo do you set the stationary rev on 03 and 04??
Yep, it works.. Just set the RPM in the Stationary Rev Limit data item...
can't wait to try it. thanks
| All times are GMT -7. The time now is 09:22 PM. |
