Service Engine Soon
Old May 21, 2006 | 11:46 AM
thekuai's Avatar
Service Engine Soon
anyway to disable this perm. in ecuflash? ive got the rear o2 sensor unplugged
Old May 21, 2006 | 11:59 AM
speed kills's Avatar
nothing yet with EcuFlash.
Old May 21, 2006 | 12:12 PM
andenbre's Avatar
it is being worked on.
Old May 22, 2006 | 11:39 PM
thekuai's Avatar
just to clear things up if i throw a code from unpluggin the rear o2, will it affect performance? will the ecu use the more conservative fuel and timing map?
Old May 23, 2006 | 04:52 AM
MalibuJack's Avatar
No,the rear O2 sensor is only an emissions related function and does not in any way affect performance.
Old Jun 11, 2006 | 02:37 PM
mike1023's Avatar
what i understand the wrx you can do this in the ecu flash how is this beening worked on you had to add somthing to the map?
Old Jun 11, 2006 | 09:20 PM
PDXEvo's Avatar
There are also several free tricks out there that you can use to, in effect, disable that O2 sensor so it doesnt trigger the SES light.
Old Jun 12, 2006 | 01:30 AM
mike1023's Avatar
so how you do that share with us all plz. im new so dont knew.
Old Jun 12, 2006 | 05:16 AM
EVO8_PR's Avatar
Spark Plug Anti Foulers...
Old Jun 12, 2006 | 06:14 AM
MalibuJack's Avatar
You have the "Anti-Fouler" trick, you can use an electronic O2 simulator, You can use the ECU+ which has the simulator built in, or you can run a Cat (though my cat does occasionally throw the CEL light)
I'm sure at some point in the future you will be able to do this with a reflash, but the coding is more complex than just changing a map or table.. Also, every (year) ECU Rom image seems to have slight variations, and the code is definitely in different places on some of the roms.
Old Jun 12, 2006 | 12:18 PM
C6C6CH3vo's Avatar
Dont let the liberals or environuts find out about this, if they do once another Dem is in office this will be illeagal. Think about it, any average joe (like myself) can install the cat and unflash the ecu before emissions once a year
Old Jun 12, 2006 | 12:26 PM
fury656's Avatar
With the current solutions out there and emissions testing only requiring an OBDII scan I doubt anyone's being fooled on this. I'd be far more concerned with ever increasing oil costs occuring on the watch of the "Laissez-faire" economists in Washington today than with fooling a sensor with a simple fix.
Old Jun 12, 2006 | 01:35 PM
donour's Avatar
It's already illegal for street cars. Stop trolling please.
d
Old Jun 12, 2006 | 07:39 PM
C6C6CH3vo's Avatar
d
Whats trolling?
Originally Posted by fury656
"Laissez-faire"
Old Jun 13, 2006 | 06:17 AM
donour's Avatar
Whats trolling?
http://en.wikipedia.org/wiki/Internet_troll
