Injector scaling and latecy for different injectors.
Old Mar 17, 2008 | 08:38 AM
  #421
bigric09's Avatar
any luck phenix ?
still looking for a good scaling for pte 1000's i can email my buddy to get his car running right
Old Mar 18, 2008 | 09:13 AM
  #422
nj1266's Avatar
Originally Posted by Phenix_fyah
Ill give um a shot man...thx
Here is what I used on PTE 880s that I scaled yesterday:
Scaling 731
Latency
3.312
2.184
1.32
0.96
0.696
0.408
0.288
The car was an Evo 9 with all the bolt-ons and HKS cams. Trims maxed out at -4 for the mid and +2.6 for the low.
Treat them as a starting point only. I have noticed that PTE injectors are harder to scale than the Densos and RCs that I have scaled.
Old Mar 18, 2008 | 09:31 AM
  #423
nj1266's Avatar
Starting point for RC 750s
Scaling:
636
Latency:
6.12
3.12
1.992
1.224
0.792
0.576
0.312
Evo 9 with TBE w/TP
Old Mar 26, 2008 | 02:28 AM
  #424
4g63_guy's Avatar
Scaling:
636
Latency:
6.12
3.12
1.992
1.224
0.792
0.576
0.312
Evo 9 with TBE w/TP
tried these settings @ idle using mitsulogger
fuel trim low: -10
fuel trim mid: -4
still haven't had the time to go for a cruise. my mods are similar to the one you set these for just w/ a HFC and arc box. any input on this as far as getting the lows closer to zero?
Old Mar 26, 2008 | 04:42 AM
  #425
TeStUdO's Avatar
Originally Posted by bigric09
any luck phenix ?
This is my scaling with my PTE 1000cc's
Scaling: 725
Latency:
7v 9.4v 11.7v 14v 16.4v 18.6v
2.186 1.281 0.771 0.458 0.283 0.172
Old Mar 26, 2008 | 07:40 AM
  #426
nj1266's Avatar
fuel trim low: -10
fuel trim mid: -4
Try this
Scaling:
636
Latency:
6.12
3.12
1.992
1.124
0.692
0.476
0.212
I lowered the latency by 0.1 in the 11-18v slots. That should bring your low trim from -10 to zero.
Old Mar 26, 2008 | 11:29 AM
  #427
silex's Avatar
Anybody here run FIC 1050/1150's or RC 1200's on stock ECU? I want to go big and never have to worry about tuning for the FP Green or E85 again But they also need to run halfway decent on 91 gas as well.
Old Mar 26, 2008 | 01:54 PM
  #428
Ph3n1x's Avatar
any luck phenix ?
Working on it. For some reason my STFT Low is not changing as often as my Mid Trim. But its getting better. I have some other issues going on with the car that I working to get resolved.
Scaling 731
Latency
3.312
2.184
1.32
0.96
0.696
0.408
0.288
Yeah but the nice thing about the Evo 9s are the Trims are reset after flash so changes occur much quicker than the Evo 8's, Thanks for the info though.
Old Apr 1, 2008 | 08:53 PM
  #429
alan678's Avatar
I have a question about fuel trims. I installed RC 1000 cc injectors and used the following scaling/latency:
The above gave me a +4 trims. After that I reduced the latency to 835. That gave me a -3 trim for both lo and hi.
So which is better for fuel economy a fuel trim of +4 or a fuel trim of -3. I think it is -3, but I want to check with you guys.
Hey NJ....these settings for the RC 1000cc are ON POINT! With the Scaling @ 835 my trims are at -1 Low and -1 Mid....good job mang!
Old Apr 17, 2008 | 11:36 AM
  #430
sub7's Avatar
Phew, just completed 29 pages worth of lesson. Could I use PTE680 scaling and latency with my Sard 700cc injector?
My current Mitsulogger showing
FTL FTM FTH
12 12 12
12 12 12
12 12 12
While Evoscan showing:
FTH FTM FTL
111.71875 100 100
Which one give more accurate reading?
Old Apr 17, 2008 | 07:06 PM
  #431
RazorLab's Avatar
FTL FTM FTH
12 12 12
12 12 12
12 12 12
FTH FTM FTL
111.71875 100 100
SARD 700cc's are Denso 720cc injectors. (really flow more like 690-700cc) Which have the info posted in this thread somewhere.
Old Apr 19, 2008 | 11:06 PM
  #432
oldevodude's Avatar
After reading through all 29 pages and prinitng out settings for my model injectors (FIC 1000's) and getting totally frustrated by the fact that the scaling provided didnt work I finally started changing latency to get a smooth idle and ended up with RC1200 latency settings on the AEM chart. What was weird is the trims could be within + or - 3% range with posted settings but idle was rough. I thought injectors might be bad fouled plugs loose vacuum line etc. but they all checked out. besides the only thing that I changed was the injectors.
Is it safe to assume these injectors just flow a lot as the latency values have to be so high to get them to operate properly?
I am in regroup mode and will "attack" again tomorrow.
OH yeah they are scheduled to open an E85 station in the area can't wait and will spread news to the North San Diego peeps when/if this station is a reality.
Old Apr 20, 2008 | 05:19 AM
  #433
dan l's Avatar
A rough idle is usually due to running too lean at idle. What is your AFR at the exact same time the car is running "rough". If the trims are maxed out and/or the car isn't in feedback it will be forced to go overly lean and get a lumpy idle (that sounds cool) but really causes a lot of stalling issues etc. You may have to add a few micro seconds of deadtime.
Old Apr 20, 2008 | 08:01 AM
  #434
JoeBee's Avatar
Can anybody give me a tipp which injector scaling to use for
Precision 780 er with E85 ?
Old Apr 20, 2008 | 11:04 AM
  #435
oldevodude's Avatar
AFR's were around 14.3 with ECU trying to adjust now It seems to be running rich although the car idles smooth as silk (AFR way down to 12's). I am prolly out of the range of adjustment. I need to download MalibuJacks program and use it for logging trims as EvoScan seems a little odd.
Thanks for the reply by the way
