ECUFlash dyno results!
Old Jul 2, 2006 | 10:06 PM
  #31
EFIxMR's Avatar
scaled to 300 here since day 1.
Old Jul 2, 2006 | 10:27 PM
  #32
gogoevo's Avatar
Originally Posted by andenbre
it would probebly be closer to 30 psi
when I hit 1.3 bar I am near 220 load on my ignition maps
and its 14.7 psi = 1 bar = 200 kpa = approx 200% load before the ecm modifys the load % with other calculations
how are you watching that?? thanks
Old Jul 3, 2006 | 12:30 AM
  #33
RazorLab's Avatar
Originally Posted by Stew
You can actually edit the axis on your load% vs RPM map. Notice on the graph posted on page 1 that the load% of 20 has been removed. He removed the 20% load column, shifted the rest to the left and added 300% at the end. Typically, as far as I take it, the trick is to find the column with the smoothest transitions from the one before it to the one after it. For example, if your timing is linear for all/most RPM from 10 to 20 to 30, removing 20 would have little to no effect since the ECU would scale the value between 10 and 30 to almost exactly what you previously had in column 20.
He actually removed load 0% and load 20% and added load 280% and 300%.
Not sure why you would even need 300% on a stocker turbo, even with race gas. I just hit load 260% at a 25psi boost spike on my 100 octane tune.
Old Jul 3, 2006 | 05:05 AM
  #34
Mad_SB's Avatar
I hit 280 every time I get in the gas at low rpm like doing a 3rd gear pull from 2,000 rpm, and I'm on a 03 stock turbo with minimal mods.
Old Jul 3, 2006 | 06:26 AM
  #35
AlwaysinBoost's Avatar
x2
Old Jul 3, 2006 | 06:41 AM
  #36
andenbre's Avatar
by looking @ logs ,watching peak boost ,compare timing logs and boost versus rpm and compare it to the ignition maps
Old Jul 3, 2006 | 06:58 AM
  #37
MalibuJack's Avatar
Running the UTEC will offset the MAF readings, even with it in passthrough it will alter the value slightly.. But generally its considered a piggyback and will alter the MAF readings before it gets to the ECU, so its very possible that your fuel table (adding fuel for some areas) would increase the MAF output from the UTEC and bump you into a higher load column..
I have several different piggybacks and all of them affect the MAF input slightly even with them completely zeroed out.. Not enough to alter it more than a few HZ, but keep that in mind..
You should see what havoc my blowthrough sensor causes when I alter its calibration output.
Old Jul 3, 2006 | 07:09 AM
  #38
Mad_SB's Avatar
Very True, the utec does alter fueling by altering the maf signal, but at this point I'm just using my utec setup (utec, map sensor, and Tuna Pro) as a $1500 logger........ I am a little worried that when I remove the utec my flash tune will be off a bit.
Still trying to decide what setup I want to go with for logging, probably ecu+, but then I have to go through all the work to add a mapsensor and wideband If I sell the utec setup.
I was also thinking about the lc-1 with auxbox, but I'm not sure if you can add a map sensor to it...
Overall, I think the ecu+with the addons will provide the most information in a single log file.
Old Jul 3, 2006 | 07:10 AM
  #39
modvp's Avatar
Thanks for all your informative responses...
Here is a question for you, the xede is said to replicate the maf signal...does it alter the maf readings causing the ecu to bump into a higher load column?
Old Jul 3, 2006 | 07:25 AM
  #40
MalibuJack's Avatar
All of them generally "replicate" or regenerate the signal, its the only way to effectively alter the output when you decide to..
All piggybacks have a small amount of error in regenerating the signal, therefore if the settings are zeroed out, it should be real close to stock, but not identical, its just the nature of the beast..
The good news is, GENERALLY the output will be close enough that removing it will not alter your tune, (this was directed at the UTEC post above)
For the UTEC guy with with the Tuner Pro, I calibrated the analog output of the Tuner Pro's wideband to the PLX Voltage (to use a PLXDevices gage, as a result, I used it with the ECU+ to log AFR using the PLX calibration, Additionally, I used the Tuner Pro's MAP sensor input and tapped the signal wire from the sensor, again running it into the ECU+ to log boost and also set its calibration for a GM 3bar sensor) So Its worth it to hold onto the Tuner Pro.. you can even use the EGT input and send that signal to the ECU+ so it can also be logged..
Old Jul 3, 2006 | 11:02 AM
  #41
RazorLab's Avatar
Interesting, my logs show that I do not on 22psi on pump gas. Either I am not or I am exceding the 260% load column but my timing is not being affected like other people are saying happens.
I also do not on 25psi with 100 octane, but I am using ECU+ to lean the fuel out, so I am in a lower HZ range.
Old Jul 3, 2006 | 11:25 AM
  #42
MalibuJack's Avatar
You'd be surprised how much an aftermarket intake affects MAF reading.. there are quite a few intake kits that lower the MAF reading quite a bit, as a result it causes the car to run lean if its untuned..
Old Jul 3, 2006 | 11:59 AM
  #43
RazorLab's Avatar
Stock intake here.
Here is the path my ECU is taking through the load columns according to my logs:
22.5psi peak, 91 octane.
RPM -- MAS Hz -- Timing -- Wideband AFR
2513 -- 384 -- 12 -- 13.1
3024 -- 636 -- 6 -- 11.9
3501 -- 992 -- 5 -- 11.4
4035 -- 1121 -- 6 -- 11.3
4513 -- 1266 -- 7 -- 11.1
5043 -- 1393 -- 9 -- 11.2
5522 -- 1492 -- 10 -- 11.2
6002 -- 1595 -- 12 -- 11
6515 -- 1694 -- 13 -- 11
7002 -- 1731 -- 17 -- 11.1
7528 -- 1796 -- 19 -- 11
pcamara17
Apr 16, 2011 06:26 AM
AlwaysinBoost
98
Nov 4, 2007 04:47 AM
dp2580
Jul 24, 2006 08:29 AM
AlwaysinBoost
May 15, 2006 06:23 AM
Scot
For Sale - Cars For Sale
May 4, 2006 05:32 AM
