Adding elements to scaling tables
If I want to add loads cells past 260 can I just simply go into edit, select edit map definition, go to X axis load and change the number of elements from 18 to 20? Playing around with a stock ROM is does indeed add 2 extra load cells at the end of the tables. You can then label them 280, 300 and then fill in the cell with the appropriate numbers. The weird thing is that all of these cell after entering values will remain outlined. Why is this? I would be nice if it was this easy.
No. See earlier posts, you'll overwrite the wrong bits of ROM and things will be misaligned. This is like writing off the edge of your sheet of paper onto your expensive wooden desk
Rescale within the available number of load zones.
wagonwes
Aug 10, 2016 08:16 PM
