My evo ix knock sum ok?
Old Jul 15, 2006 | 11:17 PM
nj1266's Avatar
Originally Posted by 5k6
Did 3 more runs today and put BP 93 in which is what it was tuned on:
Correct me if I am wrong, but shouldn't the ECU pull timing when there is increased knock sum? In the first log there is hardly any pulled timing despite that fact that the there is knock sum of 7, 6, 5 from 3600 to 5200. infact, timing goes up from 3 to 5 to 6 to 7. In the last log something similar is going on.
Old Jul 15, 2006 | 11:25 PM
5k6's Avatar
5k6
OK thanks Al I will do some more datalogs with different fuels at 21 psi and see if that helps.
Old Jul 16, 2006 | 12:47 AM
RazorLab's Avatar
Looks like you are trying to run too much timing at peak torque and it knocks every time and then pulls timing.
Is this your tune or?
Old Jul 16, 2006 | 01:11 AM
elhalisf's Avatar
0-3 counts, ecu does nothing
4-7 counts, ecu may pull a degree of timing
7+ counts, ecu pulls 1 degree for every 3 counts
this info is not yet confirmed to apply to the evo ecu's, but is now generally accepted.
Old Jul 16, 2006 | 04:07 AM
4TUN8's Avatar
and is completely incorrect. The evo ecu will pull timing on a knock sum of 1.
As for the original poster.
You really got no where by lowering the boost, your timing seems to have increased but still looks very low to me, on the stock turbo I was seeing 10-12 on peak boost and a steady rise to almost 20 degrees by redline.
Soooo....try adding some fuel.
send the logs to 4tun8@comcast.net if you need help finding where to add some fuel.
Depending on where your boost controller is tapped, this could also be an issue with a boost leak. Having your MBC tapped off the BOV for example in a boost leak condition would just force the turbo to spool harder, which would create more heat, which would make your knock counts increase (heat = more detonation).
For about 10 bucks at a hardware store you can build yourself a boost leak tester and find out what's going on.
Old Jul 16, 2006 | 04:15 AM
elhalisf's Avatar
and you got that info from where? even my logs would prove your statement incorrect. Even Al believes the same numbers i have provided.
Old Jul 16, 2006 | 05:40 AM
Mad_SB's Avatar
You need to pull a degree or so of timing from about 3000 and up. Without knowing your afrs though......
Old Jul 16, 2006 | 05:44 AM
Mad_SB's Avatar
looks to me like it pulled 4 degrees and kept it pulled for while. Just because it pulls timing does not mean timing will not ramp up it will just ramp up at a lower offset due to the timing pull. so instead of going 7,8,9 it may go 3,4,5.
Old Jul 16, 2006 | 07:34 AM
nj1266's Avatar
What you are saying is for a DSM. Does it also apply for the EVO? Here is the quote from pocket logger web site DSM section:
Knock:
Range: 0 to 43
The knock sum scale is given to represent the signal from the knock sensor to the ECU. The ECU then calculates the amount of detonation present. The higher the knock sum the more the ECU retards timing to get rid of the knock.
With a knock sum of:
3 or below, the ECU will advance timing.
Between 3 and 7, the ECU leaves timing alone.
Higher than 7, the ECU will begin retarding timing. Higher knock = higher retard, with the possiblity of seeing less than 4deg total advance at the maximum knock sum of 43.
One important note to remember is the knock sensor can detect "false" knock and retard timing. This is most commonly caused from the noisy lifters but anything it can audibly pick up could cause this.
Old Jul 16, 2006 | 07:42 AM
nj1266's Avatar
If you look at the first log, the pulled timing coincides with peak torque. This could be the results of two things. It could be that there is knock and the ECU is pulling timing. But it could also be that the ECU pulls timing by itself at peak torque. Below is a log from my EVO w/o any tune and engine management. Notice how the ECU pulls timing at peak torque.
RPM, Timing, O2
3125.0, 20.0, 0.88
3273.0, 13.0, 0.92
3438.0, 7.0, 0.92
3660.0, 4.0, 0.94
3938.0, 3.0, 0.94
4180.0, 7.0, 0.94
4430.0, 7.0, 0.94
4660.0, 7.0, 0.94
4898.0, 8.0, 0.94
5133.0, 9.0, 0.94
5355.0, 8.0, 0.96
5586.0, 9.0, 0.96
5813.0, 9.0, 0.96
6035.0, 11.0, 0.96
6270.0, 13.0, 0.96
6465.0, 15.0, 0.96
6660.0, 17.0, 0.96
6848.0, 19.0, 0.98
7055.0, 19.0, 0.98
7211.0, 21.0, 0.98
7391.0, 21.0, 0.98
Old Jul 16, 2006 | 08:08 AM
DynoFlash's Avatar
Here is a wild one for you guys - in many cases I have seen stock ecus pull timing (one or two degrees) with 0 knock counts reported in Ecu Scan
Old Jul 16, 2006 | 08:10 AM
DynoFlash's Avatar
OK here is one of the runs I did at 21 psi:
Al do you have the final log for my custom tune so I can see what the boost was at during the tune?It might of been set lower then 21 psi I can't remember.
It does not matter what boost we tuned it at, the tune that is in the car is too much on the agressive side apparently and will need to be adjusted slightly to reduce the knocking tendancy in the mid range
Old Jul 16, 2006 | 08:22 AM
dudical26's Avatar
Is there any possibility that Evoscan does not work properly on Evo IX's. I only ask because even with my bone stock evo I was getting knock counts. I even lowered my boost to 17Psi or less and I still reported knock.
Here is a log of stock map with an intake (added after the previous incident I just described) at 17 psi.
Code:
RPM	TPS	AirTemp	Knock TimingAdv
3750	100	96.548	0	13
3812.5	100	96.548	0	11
3875	100	96.548	0	9
3875	100	95.504	0	9
3906.25	100	95.504	0	8
4000	100	95.504	0	7
4031.25	100	95.504	0	6
4093.75	100	95.504	0	4
4125	100	94.46	0	3
4187.5	100	94.46	0	2
4281.25	100	94.46	0	3
4375	100	94.46	0	5
4468.75	100	94.46	0	5
4531.25	100	94.46	0	6
4625	100	94.46	0	5
4718.75	100	94.46	1	4
4781.25	100	94.46	1	5
4906.25	100	94.46	1	7
4968.75	100	94.46	1	7
5062.5	100	94.46	4	5
5156.25	100	94.46	4	7
5250	100	94.46	4	7
5312.5	100	93.416	4	7
5343.75	100	93.416	4	7
5406.25	100	93.416	4	8
5500	100	93.416	4	8
5562.5	100	93.416	4	8
5625	100	93.416	4	8
5656.25	100	93.416	3	9
5718.75	100	93.416	3	10
5781.25	100	93.416	3	10
5843.75	100	93.416	3	10
5906.25	100	93.416	3	10
6000	100	92.372	3	10
6062.5	100	92.372	3	10
6125	100	92.372	3	11
6187.5	100	92.372	3	11
6281.25	100	92.372	3	12
6343.75	100	92.372	3	12
6406.25	100	92.372	3	13
6468.75	100	92.372	3	13
6562.5	100	92.372	2	13
6656.25	100	92.372	2	13
6718.75	100	92.372	2	13
6750	100	92.372	2	14
6843.75	100	92.372	2	14
6906.25	71.37254902	92.372	2	14
6781.25	12.94117647	92.372	0	38
Old Jul 16, 2006 | 09:10 AM
nj1266's Avatar
I find this very interesting
4968 1 7
5062 4 5
5156 4 7
5250 4 7
5312 4 7
5343 4 7
At 5062 your ECU pulls 2 degrees of timing since it allegedly saw knock. Ok that is along the lines posted by DSMers. But then the 4 knock value continues and the ECU adds timing. So you have timing being added as knock continues.
Old Jul 16, 2006 | 09:19 AM
dudical26's Avatar
4968 1 7
5062 4 5
5156 4 7
5250 4 7
5312 4 7
5343 4 7
Yea I really have no idea what is going on here. I just filled up on a new tank of BP 93 instead of the mobil 93 i normally get. I am gonna go put back my stock intake back on and put the boost to 19 like stock and see what happens
