Datalogging options?
Old Jul 21, 2006 | 07:50 AM
Mr. Evo IX's Avatar
I've looked around a bit and it looks like EvoScan is the datalogging software that everyone is using in conjunction with the Tactrix cable on Evo 9's. Are there other solutions available? Also what are you all using to actually edit the maps with or is this functionality built into EcuFlash or EvoScan? I'm thinking that I will purchase the AEM Uego Wideband so I'm looking for datalogging software that will be compatible with this solution. Thanks guys!
Old Jul 21, 2006 | 08:06 AM
Stew's Avatar
As far as I know EvoScan is compatible with the wideband controllers now. I have an AEM UEGO, EvoScan for logging and ECUFlash for editing maps. I haven't got a chance to try out the EvoScan yet, but I'm going to log a bit this Sunday on the 03 Evo I'm co-driving in Auto-x.
Old Jul 21, 2006 | 11:34 AM
burgers22's Avatar
Hi
ECUflash will edit the map. I use an ECU+ for logging, it is realy good, you can also adjust the timing and fueling in the ECU+ which maybe help prevent the need for repeated flashing. It has built in knock control and a host of other feature. It is expensive compared to Evoscan but I had mine before ECUflash and evoscan came out.
MB
Old Jul 21, 2006 | 01:38 PM
Ludikraut's Avatar
Wideband compatibility is not 100% yet - e.g. it does not work with the Innovate products yet, for example.
l8r)
Old Jul 21, 2006 | 03:07 PM
Mr. Evo IX's Avatar
I should have just asked you as we will have the same setup but what are you using to view your logs with?
Old Jul 21, 2006 | 05:23 PM
djmikeymike's Avatar
i use Excel
Old Jul 21, 2006 | 05:50 PM
nj1266's Avatar
Can we use Evoscan with a PDA?
Old Jul 21, 2006 | 06:00 PM
chmodlf's Avatar
Not yet. Will most likely be on Windows OS (CE) as that is probably the easiest to port it to. When this happens is hard to say as EvoScan is not slated to be open source and is not on the "to do" list.
