21 psi
Old Jul 21, 2006 | 07:50 PM
freddiet's Avatar
21 psi
What is the boost setting that I need to achieve 21 or 22 psi?? I read how they said that the # is not like you would think it would be to convert it so I was wondering if anyone knew what the exact #'s were???
Appreciate any Positive response..
Freddie T
Old Jul 22, 2006 | 12:43 AM
elhalisf's Avatar
159 for all the load tables throughout the rpm's
and 0.00 for boost correction values
also 319 for boost limit throughout the rpm's
Old Jul 22, 2006 | 02:39 AM
jcsbanks's Avatar
I would set the boost limit lower than that if the 8 behaves like the 9. Mine is at 285, and I don't hit it with 1.94 kg/cm^2 (approx 28 PSI) overboost. It did work when it hit 2.10 kg/cm^2 (approx 30 PSI).
If you zero the boost correction values you lose any closed loop control I believe, so I would prefer to fiddle with restrictor(s) to allow a small overboost with 100% duty cycle, then you can get full boost more often - ie different temperatures, lower gears etc.
Old Jul 22, 2006 | 01:25 PM
freddiet's Avatar
now will this make the factory boost control run max boost @ 21 psi. Cause I really don't want to boost past that!
Old Jul 22, 2006 | 01:52 PM
freddiet's Avatar
bump
Old Jul 22, 2006 | 02:47 PM
jcsbanks's Avatar
The easy way is to do as stated in post #2, but if you want a responsive 21 PSI in 2nd gear on a hot day then running open loop boost is not the best way to do it for performance.
Old Jul 26, 2006 | 07:32 PM
tuning g's Avatar
what is the best way for an aggresive spool up
