Knock, pulled timing and the low octane maps
Old Jul 28, 2006 | 02:15 PM
Evo_Jay's Avatar
Originally Posted by nj1266
Don't wrap your dp. Here is why:
Hi,
Wrapping the downpipe is NEVER advisable. You want to have as little heat and back-pressure behind the turbo. Otherwise you lower its efficiency. Meaning it's harder on the turbo and the engine and you make less power, but create more knock probability.
Regards,
Klaus
and:
Hi,
When you wrap the downpipe (behind turbo) you keep heat in the exhaust gas. Heat equals pressure because the exhaust behind the turbo has to flow a higher volume. This increases exhaust speed, that's true, but the flow resistance (and therefore back pressure) goes up with the square of the gas speed.
A turbo (turbine side) runs best and most efficient with as little back-pressure as possible. Remember, the turbine in a turbo runs off the mass-flow of gases, which is dependent on the pressure difference between in and out of a turbine. You want to maximize that pressure difference.
Therefore it is advisable to wrap the headers BEFORE the turbo. This keeps the energy in the gas that the turbo uses to function. I'm too busy to calculate the % right now, but wrapping the downpipe is equivalent to reducing it's diameter.
Heat in the engine compartment would much more likely come from the turbo housing itself and the primaries (which can be wrapped). The downpipe will not contribute as much as it is quite a lot cooler. The high pressure exhaust gas expands in the turbo and thereby cools down.
Regards,
Klaus
http://www.innovatemotorsports.com/f...ead.php?t=4000
I would never wrap a downpipe or a header, but I do ceramic coat them. With 05+ EVOs, the ACD & oil pan should be protected from heat, which make the coating a great idea. Also, faster exhaust gases is good, but like Klaus said, you want less back pressure (I dont know/think that coating increases backpressure)
I know you love Klaus and that he is the super engineer, but I dont think he works on EVOs. WORKS recommend coating their DP and O2 housings. Also Buschur coats the manifold and their O2 housing.
If Klaus is right, then why do top EVO tuners coat exhaust parts after turbo??
EDIT: Exhaust wrap usually lead to cracked exhaust pieces. Ceramic coating is the way to go and the only method I endorse.
Old Jul 28, 2006 | 02:26 PM
AlwaysinBoost's Avatar
On every turbo car I've owned I wrapped/coated exhaust parts and didn't notice any loss in performance. I mostly did it to keep engine bay temps down which worked excellently. I'm not disagreeing with what Klaus is saying, just giving my real world input.
Old Jul 28, 2006 | 03:25 PM
MalibuJack's Avatar
The wrapping tends to trap moisture which accelerates the decay and fatigue of the parts.. Thermal coating has mostly superceded the wrapping these days..
Most of us don't wrap the downpipe or coat the downpipe because we want to let the heat escape after the turbo.. I did make some heat shields for some other parts, but the only time real wrap is used these days is to prevent extreme heat from damaging a part adjacent to the hot part.. I've been using adheasive heat shield material on my lower intercooler pipe to protect it from the heat of the downpipe and dump tube.
Old Jul 28, 2006 | 03:32 PM
nj1266's Avatar
RMR sells a heat shield that you can glue to the oil pan where the dp passes. I believe SCC did a review of the part and said that it works.
Old Jul 28, 2006 | 03:33 PM
nj1266's Avatar
Did you do a before and after dyno testing or 1/4 mile testing to see the impact of wrapping?
Old Jul 28, 2006 | 03:57 PM
RazorLab's Avatar
Did you?
Old Jul 28, 2006 | 06:36 PM
Evo_Jay's Avatar
What about the ACD??? Also, I've seen those glue on heat sheilds and they usually fall off very quickly.
Also I was think bout it, if the exhaust gases in a coated/wraped DP go faster, wouldn't there be less backpressure???
if less backpressure = faster exhaust gases
wouldn't faster exhaust gases = less backpressure
sorry to the OP for going off topic
Old Jul 28, 2006 | 07:35 PM
I dyno and track my cars a lot. More track time then anything else though. Like I said I did it more for the heat control aspect then anything else. I never did just the wrapping as a mod and then went to the track to see if I gained anything. But from being under the hood all the time at all operating temps I can say there is a absoulte difference with the wrap then without, which is what I was after.
this isn't an EVO but you get the idea...
Old Jul 28, 2006 | 10:35 PM
nj1266's Avatar
Originally Posted by razorlab
Did you?
Don't shoot the messenger. If you want to wrap your dp, then have at it. I am just relating to you what a knowledgeable automotive engineer said about this. Do whatever the heck you want.
Old Jul 29, 2006 | 12:54 AM
RazorLab's Avatar
Any other engineers you can copy paste in here?
Old Jul 29, 2006 | 05:19 AM
C6C6CH3vo's Avatar
Regards,
Klaus
and:
I thought heating the gases behind the turbo will only increase the energy accross it from the higher velocity of gas evacuation
It does keep heat off the oil pan, also transfer area
Old Jul 29, 2006 | 06:50 AM
nj1266's Avatar
So you have a problem with automotive engineers? The whole idea of a forum is to share with other people what you read or did. I guess I missed the rule where you cannot quote automotive engineers in forums.
Old Jul 29, 2006 | 06:52 AM
nj1266's Avatar
If you do not believe what the guy is saying, then do not do it. Go ahead and wrap your dp.
Old Jul 29, 2006 | 06:56 AM
MalibuJack's Avatar
Nah, it offers very little value after the turbo, in fact the expanding gases exiting are supposed to help reduce backpressure, while before the turbo and at the header, keeping the heat in keeps up the velocity.. I suppose it doesnt really make "sense", but my theory is that as the heat is shed in the exhaust system, and the gases expand, it draws additional waste gases with it.. A high pressure/temp area to lower pressure/temp area.. Some sort of thermodynamics going on.. Turbo cars obviously dont benefit from exhaust scavenging in the same way as a Normally aspirated car would, so I think the benefit of wrapping the downpipe may only be heat control and not gain you much at that point.
The common theory on wrapping/thermal coating is..
If you need to protect other components from the heat, you heat wrap, if you need to retain the heat inside the component, you thermal coat.. Some do both, especially if you have a hot part, next to a part that needs to remain cooler...
If you want to do it, its not going to hurt anything except the lifespan of the downpipe.. If your doing it to eliminate some sort of rattling on the downpipe to the crossmember or some other component, then I would use some sort of insulator instead to keep it from rattling.
Old Jul 29, 2006 | 04:18 PM
C6C6CH3vo's Avatar
Take the same amount of heat energy going into two seperate but identical ducts of somewhat restrictive diameter. The one that is insulated and retains more temperature will evacuate the gas better, right?
I do see the point about heat differential accross the turbo, but were talking DP wrap and not on the O2 housing
