Inmobilezer code problem
Old Aug 5, 2006 | 11:38 AM
onpol's Avatar
Hi Gurus,i'm trying to load a map from a vehicle to another and when i go to the inmobilizer option to change the data i press edit and change the code and it just leave the old one there.I'm i missing something?
Thanks
Old Aug 5, 2006 | 11:41 AM
ohio-evo's Avatar
Where do you find the code? I was looking the other day so I could write mine down and did not see it.
Old Aug 5, 2006 | 11:57 AM
cpoevo's Avatar
Go to OPTIONS>options......userlevel and select developer. Then open the ROM. You have to do this before you open the ROM. Under misc. in the ROM you will see immobilizer. Write this code down. I wrote everything down about my ecu. I havent fugured out how to change the immobilizer code though. I have tried and it stays the same.
Old Aug 5, 2006 | 02:03 PM
onpol's Avatar
I found the way to change it.Open both inmo. windows the one that have your code and the one you want to copy the code to and do a copy paste and it works.
Old Aug 5, 2006 | 02:04 PM
Jorge T's Avatar
You have to convert the Hex16 code to a decimal system number. To change the code go to Edit and enter a decimal number or click on the hex16 hit the = and enter a decimal number ie 65535=FFFF.
Use excel function =HEX2DEC(Hex16) to convert your immo code to decimal and save your decimal number in a safe place.
Old Aug 5, 2006 | 04:17 PM
sesso's Avatar
i just put an x in front of it to state its hex and it worked for me.
