Help reading map
Old Aug 9, 2006 | 06:40 PM
swordfish's Avatar
Help reading map
Friend just bought an 04 EVO and it has a tune of some kind on it .... Anyway we just pulled the ROM image but the scaling is crazy and we cant read it. Please help. Thanks
Map can be found here. http://www.madkobayashi.com/ECUFlash/
jeff
Old Aug 10, 2006 | 05:38 AM
Stew's Avatar
I can't download the map. I get this:
You do not have permission to access http://www.madkobayashi.com/ECUFlash/bus.hex
The extension hex is currently not supported by FreeServers.
If you think there is an error or you wish to have the extension hex added to the mime definitions, please take the time to notify customer support.
Thank you for using FreeServers.
Old Aug 10, 2006 | 06:37 AM
swordfish's Avatar
Woops. Didnt know my freeservers didnt support that. Here is a zipped version.
www.madkobayashi.com/ECUFlash/bus.zip
jeff
Old Aug 10, 2006 | 07:18 AM
Stew's Avatar
Yea that's weird. You pulled that right off his USDM 2004 Evo VIII?
Old Aug 10, 2006 | 09:02 AM
swordfish's Avatar
Yep. Just connected and downloaded the map just like with my 05 and it showed up like that. I tried a couple of more time but it always looks the same. Haven't had this occur with any other maps.
jeff
Old Aug 10, 2006 | 09:32 AM
MalibuJack's Avatar
It is associated with an incorrect definition, or one that has to be updated. What is the ECU Identifier? There are a few not completely defined that are similar enough to what is out there, you just need to find one similar and make minor changes to fix the axis/scales Don't do this yourself if your not comfortable with it.. But identify which ECU It is by the number and post it here.
Old Aug 10, 2006 | 09:39 AM
burgers22's Avatar
Hi
I have just opened this hex file using the 9642007 definition. All peramiters apper to display correctly.
MB
Old Aug 10, 2006 | 09:48 AM
MalibuJack's Avatar
What was the actual ECU's definition though? It'll help me match it and fix it easier when I get home later. I can figure it out from the rom, just wanted a jump start since I can't do it here.
Old Aug 10, 2006 | 11:22 AM
burgers22's Avatar
Hi
ECU def is 9642008.
MB
Old Aug 10, 2006 | 05:32 PM
andenbre's Avatar
Originally Posted by burgers22
Hi
ECU def is 9642008.
MB
yeah thats what I used and it read fine
Old Aug 10, 2006 | 05:54 PM
C6C6CH3vo's Avatar
I remember going through something like this, not sure it's the same problem here but, the load and RPM would display an unusual incorrect value. Ended up being the wrong 04 identifier loaded from what was listed on the ECU lable. My dislexic mind switched the numbers around on two of the 5 (I think) 04 identifiers.
I put the right ID in and then suddenly, I'm able to tune my own car and pretend to be smart
