Suddenly ignition cut, Log inside
Old Sep 14, 2006 | 01:47 PM
Fredd^'s Avatar
Hi
My car has gotten suddenly ignition cut and I haven’t done anything with it.
The problem starts above 5k RPM, it’s like the car struggle for air or fuel.
I don’t get the problem if I rev the engine standing still. Only when driving
The boost are fine also and lies about 22-23 PSI
I attach evoscan log as I don’t understand all the numbers so far 
I renamed it to txt
Mods done to the car
ECUTEK
Full exhaust
Walbro 255
Open air filter
File Type: txt
Old Sep 14, 2006 | 01:52 PM
jcsbanks's Avatar
I don't see anything in the log to explain your problem.
Old Sep 14, 2006 | 01:59 PM
Fredd^'s Avatar
Well when cursing under 5k RPM the car goes great but as soon I get over 5k it get like a hiccup, and it feels almost like boost cut I had before the tune, but not exactly like it. If fells like the ignition but I don’t know, its sound like fire crackers on new year…
It can be the spark plugs to, I need to check that this weekend. But there are new HKS that’s only made a couple hundred miles
C6C6CH3vo's Avatar
That was a 2nd gear pull, correct?
Old Sep 14, 2006 | 02:01 PM
C6C6CH3vo's Avatar
There possibly lies your problem. Put the stock ones back in
Did you get a 0300?
A messed up ignition pulse wont show up on the scanner but a 0300 fault would almost confirm bad spark
Old Sep 14, 2006 | 02:05 PM
Noogles's Avatar
Checked your plugs to make sure both the electrode and porcelain are in good shape i've gotten bad plugs out of the box.
Old Sep 14, 2006 | 02:11 PM
spm1024's Avatar
edit: just saw that you don't have an airbox. nevermind.
did you happen to forget to put the plastic keepers back on your airbox snorkel??
i have heard that will cause similar symptoms. your snorkel gets sucked up onto your hood and the car cant get air.
Old Sep 14, 2006 | 02:19 PM
Fredd^'s Avatar
No 3rd why ?
Old Sep 14, 2006 | 02:22 PM
Fredd^'s Avatar
Did you get a 0300?
Do you mean in evoscan or what ?
I was way to stressed to look at it, just hit start logger and stop then ran in to upload,
My laptop died 1min after I got in, no battery left.
Old Sep 14, 2006 | 02:24 PM
Fredd^'s Avatar
Yes I will check them tomorrow, if the fault lies with the HKS plugs I will throw them back at the tuner. I really don’t like denso, have seen to many faults with them.
Old Sep 14, 2006 | 03:16 PM
Noogles's Avatar
Does NGK make plugs for the IX yet?
If they do get those, i've never had a problem and i've had them gapped down to as low as .020 and had them last 10k miles.
Old Sep 14, 2006 | 03:36 PM
Fredd^'s Avatar
I haven’t seen colder than the standard 7 on the NGK but I will look at it , the standard ones are iridium 7 but I want at least 8 or 9.
Old Sep 14, 2006 | 03:41 PM
C6C6CH3vo's Avatar
No 3rd why ?
Because your car accelerated through 4250 - 6250 rpm in just 2.1 seconds - about 0.5 seconds fast for basic bolt on IX's
Yes I meant EvoScan
5 speed?
Old Sep 14, 2006 | 03:46 PM
Fredd^'s Avatar
5 speed?
No 6 speed
12.12 1/4 mile @114 m/h if that say anything. dont know if thats good or bad over there...
Old Sep 18, 2006 | 02:36 PM
C6C6CH3vo's Avatar
No 6 speed
4250 - 6250 rpm in just 2.1 second is extreem for a 5speed I was considering, but now I know it's a 6 speed - still for a 6speed I guess it's fast too - 12.1 ET not bad at all - 23 psi, was that on 94 octane?
Anyhow what did you find was the cause?
