Attempt for the final answer.
Old Nov 1, 2006 | 08:28 PM
coolguycooz's Avatar
Ok i know asking this question will probably get me no where, based on the fact that nobody buys every single intake filter and logs it with evoscan to see witch alters the MAF signal less.
But can anybody make some solid suggestions with numbers backing up on a final answer on what intake filter to go with, because the pressure drop with the stocker vs the airbox has been proven to be significantly higher.
I will of course attempt to tune it to the best of my ability once the filter is on.
Before i order the filter i just want one final say.
Does that apexi setup with the inverted cone do what it claims it does with the stabilizing the air for the MAF.?
Old Nov 5, 2006 | 07:39 PM
come on now atleast a response like, " Aftermarket Intakes are garbage stick to your stock Air box all the way through 400 hp.
