Going to JDM land
Old Nov 8, 2006 | 08:04 PM
cpoevo's Avatar
Going to JDM land
I will be going to Japan for about 2 weeks the end of the month. What JDM parts do we need to try out with Ecuflash?
I know the JDM MAP sensor is one part are there any others?
I am not sure how much time I will get off in Japan or if I will even be able to find these parts, but I will try. Sopost up the parts.
Old Nov 8, 2006 | 08:13 PM
MalibuJack's Avatar
I definitely need the JDM Map sensor if you can grab one for me.. Offhand almost everything else is the same between the US and Japanese spec cars.
Old Nov 8, 2006 | 08:14 PM
jroller's Avatar
Oooh see if you can stop in Singapore, you'll thank me later. Unrelated I know.
Old Nov 8, 2006 | 08:32 PM
cpoevo's Avatar
Been to Singapore like 6 or 8 times. I am a Chief and have done 6 WestPacs. I have been to the "Four Floors of ******".
Old Nov 8, 2006 | 08:33 PM
cpoevo's Avatar
Will do my best to get it MJ.
Old Nov 9, 2006 | 05:27 PM
jroller's Avatar
Ha, ha that is awesome. You just made my friends list.
Old Nov 9, 2006 | 11:23 PM
nvr2fast's Avatar
Can someone tell us what's the deal with the JDM MAP sensor? I only ever had a JDM car, so is there something wrong with the USDM one?
Old Nov 10, 2006 | 05:39 AM
MalibuJack's Avatar
The US cars have an MDP sensor, Its still a MAP sensor, but doesnt read over roughly 1 bar absolute (Sea level plus a few thousand feet) The Japanese sensor is 3bar and can read boost pressure. (As far as I have been told) and its a direct swap to the american car and should require little if any recalibration of the ECU to use.
Old Jan 28, 2007 | 09:19 AM
voidhawk's Avatar
bump ... did this ever get tested? Also, does anybody have a part number?
Old Jan 28, 2007 | 09:36 AM
MalibuJack's Avatar
Yep, the sensor works, but it has unintended side effects on most cars, which require us to figure out the calibration table for the sensor if we want to swap it.
