Code P0171 After EcuFlash
Old Nov 10, 2006 | 08:01 PM
MR. Birdie's Avatar
I had the car for several months and everything was fine for the first 3 months. The code P0171 ( system lean condition ), pop up. I didn several search and people state it was a common problem after a tune, is there any way to solve this problem? Do i have to take it back and let them adjust more fuel? My A/F ratio was 11.5 with the final tune.
thank you
Old Nov 11, 2006 | 06:38 AM
SophieSleeps's Avatar
I dunno why this would be in the ecuflash forum.
It has nothing to do with the type of flash.
If your car is throwing a lean code, it is an indication of a serious problem.
It doesn't sound like you tune yourself.
You should take the car back to whoever and have them redo it.
Old Nov 11, 2006 | 06:43 AM
04WWRS's Avatar
I believe that code is lean at idle.
Old Nov 11, 2006 | 04:36 PM
Probably lean during closed loop...not necessarily idle.
Old Nov 12, 2006 | 07:57 AM
04WWRS's Avatar
could be. Here's all the codes.
http://www.obdii.com/codes.html
Old Nov 12, 2006 | 08:41 AM
Mad_SB's Avatar
it is bank1 sensor 1 lean, so the front 02 is reporting a lean condition, if the trims are so far out that the ecu cannot add any more fuel, it will throw the code. does not have to be at idle.
I would replace the front 02 sensor and see if that fixes the issue.
InitialE
Oct 21, 2014 08:27 AM
jonny_502
Lancer Troubleshooting
Sep 6, 2014 06:23 PM
mikebuff35
Aug 29, 2014 09:13 AM
piponpi
Jan 23, 2014 03:04 PM
Steven_Trujillo
Jan 11, 2014 07:09 PM
