ECUFlash / Evoscan / Mitsulogger Questions
Old Apr 17, 2007 | 05:19 PM
  #196
MalibuJack's Avatar
You have several problems.. windows ME doesn't have drivers for the tactrix cable, at least current ones specifically for the Tactrix cable.
There is limited .NET support to begin with, and the OS is end of life for microsoft so there is no longer any updates.
Your only option is to upgrade to windows XP assuming your laptop can run it.
Sorry..
Old Apr 17, 2007 | 07:00 PM
  #197
Jer.k's Avatar
I guess thats not something I can do myself...I thought Evoscan stated that Windows ME was 1 of its laptop operating systems? Also, I ordered 1 of the limitless cables for datalogging and reflashing the Evo...not sure if that makes any difference.Thanks
Old Apr 19, 2007 | 09:30 AM
  #198
InsaneEvolution's Avatar
Im having a hard time logging an AEM. It worked for about two days and now it makes Evoscan .99 go crazy.I have to uninstall it in order to log the evo without the wideband hooked up.It tries to reconnect 40 times.
Old Apr 19, 2007 | 09:36 AM
  #199
trinydex's Avatar
is that just a bug wtih 99?
Old Apr 19, 2007 | 09:42 AM
  #200
Well I haven't tried the Mitsulogger 1.6 yeat.so I'm not sure.But it did work at first.Now it says "cannot connect to com1, access denied." have only one serial port on my laptop.
Old Apr 19, 2007 | 10:10 AM
  #201
I think its hardware related on my laptop but Im not the CPU literate.It does the same thing with the mitsu logger .Access denied to com 1
Old Apr 19, 2007 | 10:22 AM
  #202
Q8_EVO's Avatar
I got this message while trying to install the program
the application failed to initialize properly .. blah blah
how can i fix it ?
Old Apr 22, 2007 | 09:08 PM
  #203
vmrevo9's Avatar
Veteran: Air Force
hey guys i was trying to figure out where in evoscan (if it does) does it calc boost? someone told me that it does it with load but which one and how do i convert it?
Old Apr 23, 2007 | 01:05 PM
  #204
rodrig.diaz3's Avatar
Immobilizer code
MJ where is the Immobilizer code on my Evo IX.
Really aprecciate your help.
Old Apr 23, 2007 | 04:10 PM
  #205
Chemwarrior's Avatar
I'm trying to run MitsuLogger, but I'm getting an error message that says "The application failed to initialize properly (0xc0000135)". Can anyone provide some insight? Thanks.
Old Apr 24, 2007 | 06:17 AM
  #206
vmrevo9's Avatar
Veteran: Air Force
bump for newly posted questions!!
Old Apr 24, 2007 | 10:16 AM
  #207
Im still in the dark about why my laptop wont log the AEM wideband.It work for two days.Ive tried almost everything.
Old Apr 24, 2007 | 10:35 AM
  #208
TouringBubble's Avatar
There is no set boost calculation using the ECU. To log boost, you'll need the JDM MAP sensor or one of many aftermarket kits that incluse an extra MAP sensor. You can calculate boost in EvoScan with the JDM MAP sensor, which is a direct replacement for stock with some minor ROM modification. EvoScan .99 already has the calculation set up for you.
The load comment you've heard refers to the load numbers being relative to the boost curve. There is no conversion formula that I know of to calculate boost from load. See the image below for an explanation ...
The boost curve visually follows the load curve. this is why a lot of people will say "You're peak load is XXX ... that's about XX psi."
Old Apr 24, 2007 | 11:05 AM
  #209
V.8MR's Avatar
Originally Posted by MalibuJack
It depends.. If your comfortable with logging tools and correlating data, then you should be fine with either. If you want the integrated logging, Evoscan has support for several widebands. (Mitsulogger will support widebands also, its just the app isn't being worked on at the moment since I have other things taking up my free time for awhile)
You can also check out ECUEDIT.
Mitsulogger is the only freeware logger tool though..
Does mitsuloggers load values directly correlate with ecuflash interms of load cells.
Old Apr 24, 2007 | 11:26 AM
  #210
vmrevo9's Avatar
Veteran: Air Force
Thnak you for the info!
